How to remove fuel from tank
I hooked up a electric pump to the pick up and nothing happens, I put a line down the filler neck to the pump and still nothing. Do I need to prime the pump? I woud like to use this to get the fuel through a filter to reuse fuel.
CAN'T FIX NOTHIN
Re: How to remove fuel from tank ?
(LOL) just funnin here but the way I remove the fuel from my tank is to STEP ON THE PEDAL !!!!!!!! ![]()
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
Lemme show you something!!
Are you sure there is fuel to be pumped out ?
Make sure you have it connected to the outlet line and not the vent. Test the pump with a known source such as a mason jar full-o-gas to rule out a bad diaphram or rotary vane in the pump itself.
'67 CST-10 LWB ("Crusty") SOLD '67 GMC SWB ("Murdock") 2000 K1500 Suburban ("Betty") '95 BMW 325i ("Joy") |
is Certifiable
Could put it on one of these and put a drip pan under it
![]() http://www.eastwoodco.com/shopping/p...roductID=17072 |
these tanks are easy to pull out, when i took mine out a fe months ago i just took it out, and dumped the fuel out into a gas can w/ a funnel in it.
might be harder if it all the way full of fuel tho |
Shifter in D, pedal to FLoor..ENJOY!!
Saving 1 truck at a time!
Disconnect the fuel line at the fuel pump and let it drain into a gas can.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
Gravity sucks.
Well when mine is full I just drive it around the block... now its empty
Theres only one tube coming out of the tank, and a small screw which I believe is the sending unit. If I could just pick up the tank and tip it, I would but has at least ten galllons that I could figure and it is sitting on the flooor.
I tryed using a 12v inline pump attached to the outlet line on my`92 diesel side-mount tank (facing front downhill) and got nothing.I had about 18 gallons in there.Then,I attached a long piece of fuel line and stuffed it down into the tank all the way up front (lowest point) and it sucked it all out.There may have been a qt. left in there.But,to remove those tanks,it`s easiest to pull the bed.That`s the only way I`d even try it.But,I have a steel Reading work cap w/ladder rack (1,000#approx.).That`s the only reason I didn`t pull the tank.I`d just pull the seat and yank the tank.
