cross shaft adjustments?
I believe the upper cross shafts are threaded for some front to back adjustment. Now this may seem crazy but can you just shift (adjust) these forward or back to get more (or less) caster? does it mess up the other alignments?
I would like to do the upper a-arms IF they would help the feel and drivability of my truck. I have a static drop only with spindles I dont know where my alignment is at right now but I had it done after all my front end changes. any thoughts would be great!
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
Re: cross shaft adjustments?
there are 2 bolts on cross shafts. to adjust caster and camber you can add/remove "shims" you can buy them at auto parts stores to alignment shops.
loosen the nuts up +/- the shims then tighten them back up
-A DAM WILD MAN- 59 apache pannel truck 38 I-6/sm420 79 malibu wagon 305/t56 02 2500hd duramax/allision 1/4 13.82 @100 mph efi live and built tranny 500hp 383 on the engine stand ![]() U.S. Navy 2000-Current Peace through Superior Firepower Horsepower = Condom.....I would rather have it and not need it than to need it and not have it |
I know that is how they are adjusted but didnt know if moving the cross shaft would help in gaining some caster then using the shims to get the camber back in place?
Dave
it controls both
