02-28-2008, 02:52 AM | #1 |
Door Hinge Friction Pads
Anyone here have expeience replacing the friction pads on the upper door hinge? I'd appreciate the procedure for that.
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus! |
02-28-2008, 06:06 AM | #2 |
Re: Door Hinge Friction Pads
The stop has to be removed from inside the door after you drive the roll pin out. Once the stop is out, the pads can be removed. Replacement pads are available but I cut the friction blocks out of old brake shoes, shaping to fit. I use trim adhesive to glue the friction blocks in place. The home made friction blocks work well for a long time!
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
