Doing a axel swap from 87burb to 70 chev?
A local guy has a 87 3/4ton suburban 4x4 he's parting out. First will the fit be right? I'm getting the hole shooting match springs and steering stuff. Is this a bolt in bolt up modification? Thanks Bob-- my truck is a 1970 4x4 6 hole
1970 k20 350 4speed hd44 14b Circumventing the language filter is against site rules |
I'm a poor spectator
Re: Doing a axel swap from 87burb to 70 chev?
Springs are too long, spring perches on axle are too narrow and will have to be relocated.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
![]() Join Date: Nov 2007
I think that's only partially true. Are you wanting to swap in the front and rear axles? Jtrux is correct on the rear axle. However, the front axle should be a direct bolt it, using your current springs.
Thanks for the replies. What Year and back would be a bolt in for me. Or is it only a burb to pickup thing?
If you find a one ton 73-91(?) 4x4 the rear axle will go in w/ out moving perches but the shock mounts will need moved.Or for the rear look for the good ol bullet proof Ho52 from a 69-72 Chevy or GMC and use it in the rear,better than a 14 bolt IMO. The fronts (44 or corp 10 bolt) will go in with no mods from a truck,blazer,burb with a solid front axle.If you can,get the spring plates,and u bolts as the ones from a corp. 10 bolt are different than ones from a dana 44 (Different axle tube size) but if you cant the ones you have can be made to work.Of course if you find a one ton 4wd grab the front axle (Dana 60) out from it if you can!
