Old 02-28-2008, 03:52 AM   #1
Mtnman
1958 fleet side shortbox
Hello to all I am not new to the board I just spend most of my time researchin instead of writing
So after hours of searching I still have not found a definte answer
so here is my question Can I take my 58 and put it on an 81 short box frame
has any one done this
or am i stuck with the camero frame swap
thanks LT
Mtnman is offline   Reply With Quote
Old 02-28-2008, 04:03 AM   #2
prostreeter58
prostreeter58's Avatar
Re: 1958 fleet side shortbox
thanks LT
You can't do nothing here without pics.............lots of pics..........
prostreeter58 is offline   Reply With Quote
Old 02-28-2008, 04:11 AM   #3
Mtnman
um pics of a 1958 fleetside short box or of an 81 short box
I just wanted to know if there are tricks and such
also wondered about dementions
I have all the peices so I could go measure
just wondered if any one had done this before
cause im thinking about it now and this weekend I can measure for my self
Old 02-28-2008, 04:26 AM   #4
Huck
Huck's Avatar
You can put the 58 body onto a newer frame with some fabrication for cab, bed and front clip mounting mounts.
Huck is offline   Reply With Quote
Old 02-28-2008, 05:18 AM   #5
entourageguy
Yellow truck club
entourageguy's Avatar
You could check out tiggers install on a 77 frame..
http://67-72chevytrucks.com/vboard/s...d.php?t=262874
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 02-28-2008, 07:26 AM   #6
poncho_villa
poncho_villa's Avatar
With a tape measure, pencil and a sketch pad, I would crawl around under both and map out the cab and box mounts. Then you can compare to see how far off they may be. If you can cut, weld, and fab, you can do it. First thing to compare is the wheel bases of both. Oh! and don't forget about the pics!
poncho_villa is offline   Reply With Quote
Old 02-28-2008, 11:58 AM   #7
56hotrodred
Ya I am putting a 56 on an 80 frame. Bit of fabrication but nothing too bad especially with all the help available here & elsewhere.
If I was to start over I might look at an even later frame with torsion bars. Lots of info around for that swap also. Not sure what other issues there would be.
Do searches in this and other forums (i.e. chevy talk & stonebolt). Tons of information out there.
56hotrodred
56hotrodred is offline   Reply With Quote
Old 02-28-2008, 11:59 PM   #8
the professor
It can be done my 58 is on an 80s model frame with whit walls and it rides great. the whells in the back just sit about 3 inches to farback in the fender well
the professor is offline   Reply With Quote
