02-28-2008, 05:15 AM | #1 |
Throttle body from 4.3-350..can I use it?
I have a throttle body unit from my 88 Astro and was wondering if it could be used on a 350 if the the computer is changed. All I have is the unit itself and it does have brand new injectors. I'm certain I'd gert neough flow out of it but I'm just wondering what's needed. But I could be wrong and way off.
02-28-2008, 05:41 AM | #2 |
Active Member
Re: Throttle body from 4.3-350..can I use it?
I think the computer also monitors engine/water temp, airflow (MAF), ignition timing plus exhaust combustion to determine how much fuel to inject into the engine. A lot of variables are computed for correct air/fule mixture.
I'm not an expert on modern engines, but it seems that you would have to install all of the additional components (sensors). |
02-28-2008, 06:00 AM | #3 |
As far as I know the throttle bodies are the same, (4.3, 305, 350), but the injectors are different.
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
