Old 02-28-2008, 07:21 AM   #1
Big Irish
Big Irish's Avatar
Shock Part Number
I am running a CPP ntch and bag kit in my 67 . I have shock relocators . I can't seem to get the correct rear shock hieght/length . Anyone know a specific shock and or model number I could by to stop bottoming out my shocks .
Much appreciated .
1955 Chevy 2 door Wagon
1967 Short Wide BAGGED Gone to someone else
1953 Shop truck Clipped and Snipped sold
1951 GMC Bagged and patina
Big Irish is offline   Reply With Quote
Old 02-28-2008, 08:24 AM   #2
leftcoast66
leftcoast66's Avatar
Re: Shock Part Number
Have you tried calling CPP and asking them what they use with that kit if any of them have it? Otherwise I would try and call summitracing and tell them how much you lowered the truck and they'll find you some shocks that are the right dimensions, that's what I did when I bagged my c10.
leftcoast66 is offline   Reply With Quote
Old 02-28-2008, 09:13 AM   #3
Big Irish
Big Irish's Avatar
i will try that thanks .
Old 02-28-2008, 09:30 AM   #4
shifty
Questionable
shifty's Avatar
CPP shocks are overpriced.
This is some information that another boardmember shared with me (gringoloco), along with some information shared by yet another board member (XXL):
(I don't know which part numbers are correct for your application, if anyone can clarify please do! These shocks are supposedly only ~$15/each)
Originally Posted by gringoloco
Get the cheap Monroe-Matics. They are the dark blue, plain-jane shocks you can get anywhere.
Use pn 33033 up front.
For the rears, I have heard of people using 32077s and I also stole this from XXL:
Originally Posted by XXL
Stock = 32301
top mount LS37, bottom mount LS37, compressed 11.875, extended 18.250, travel 6.375
Shorter unit = 33076
top mount LS37, bottom mount LS37, compressed 10.000, extended 14.625, travel 4.625
Still shorter unit = 34839
top mount LS37, bottom mount LS37, compressed 9.750, extended 14.750, travel 5.000
Even shorter unit (requires small mod to bottom mount) = 37187
top mount LS37, bottom mount L1/CP5, compressed 9.375, extended 14.250, travel 4.875
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 02-28-2008, 10:40 AM   #5
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
You might want to spend a few extra bucks and get the Sensa-Trac's. I have them on my truck and they work great. As far as your application goes, here is a link to the Monroe application guide... Find your mounting styles, measure your fully compressed and extended lengths and choose your shock from the list.
http://www.monroe.com/catalog_lookup...engthSheet.pdf
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 02-28-2008, 06:23 PM   #6
Big Irish
Big Irish's Avatar
thanks for the suggestions , it's appreciated .
Old 03-03-2008, 08:04 AM   #7
BigSky71
LAIDOUT
BigSky71's Avatar
C10Driver, I am combing through the shock list and can't find the Sensa Tracs with the right lengths. Do you know what the front Sensa tracs are that you used? Thanks much.
Ok more digging on the front shocks I think these are the part numbers; Monroe Matics 33033, Sensa Tracs 37049 [I think], Reflex 911049. The reflex ones provide "better stability", I would assume that is just more built in compression damping, but that's just guessing.
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
