Old 02-28-2008, 09:19 AM   #1
tsetsaf
Steering Wheel Removal
Looking for some tricks on how to break loose a steering wheel from my 71.
Already tried:
- Steering wheel puller
- PB blaster
- Pressure with a smack from a hammer
Any ideas are welcomed as I will attempt them all until I succeed.
Thank you,
Mark
tsetsaf is offline   Reply With Quote
Old 02-28-2008, 09:38 AM   #2
60ratrod
yes, i do
60ratrod's Avatar
Re: Steering Wheel Removal
did you try hitting the big screw that applies all the pressure?? i had to do that once or twice and it worked out fairly well. i would also soak the collumn shaft that the steering wheel fits on to for a bit longer. but i would definately try smacking the center screw of the steering wheel puller. get the screw to where you can't turn it anymore, smack the screw with a hammer, and it should come loose. lather, rinse, repeat till it comes off.
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 02-28-2008, 06:28 PM   #3
short step
put pressure on the wheel w/knees and 1 hand and hit the stud w/a brass or lead hammer
bob
short step is offline   Reply With Quote
