"Where were you in '62?"
![]() Join Date: Jul 2004
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Any of you fellars out there have any Pro/street Beaters or Drag Trucks out there ,send me some pics so I can get some Ideas. I am pro/streeting my 62 chevy that I have had sence High school! This is all the stuff that I have done to it............... Where were you in 62? F A C T S & F I G U R E S Bryan Stephen Lail Kings Mountain, NC 1962 Chevrolet C10 1/2 Ton Nostalgia Pro/Street Truck C H A S S I S Frame / Manufacture Modified stock / Chevrolet (Father) Steven B. Lail Kings Mountain, NC Modifications Altered Body & Frame Mustang II IFS Clip Wheelbase 117 Rearend / Ratio 58 Ford Wagon 9 / 3.70:1 Rear Suspension Mono Leaf Springs, Shocks Gas Rear Brakes 11 Drums Front Suspension Mustang II IFS Master Cylinder Mustang II Steering Manual Steering Steering Column GM Non Tilt Front Wheel make, size Weld Draglite 15x7 Rear Wheel make, size Weld Draglite 15x12 Front Tire make, size 215/65SR1596H Rear Tire make, size Mickey Thompson 29x15.50-15LT Tube Type Gas tank Aluminum, Fuel Cell (20 gallon) E N G I N E Year and Make 70 Chevrolet Displacement 350ci LS9 Cast Iron 4 Bolt Main (.30 over) 400hp@5000RPM 380Ft. Lbs@3800RPM 9.5:1 Compression Ratio Pistons Hyperedic Cast Aluminum Flat Top Camshaft Hydraulic Dual Pattern (Lift .443 Int., .465 Exh.) Crankshaft Nodular Cast iron Cooling Fan Heads Chevrolet 291 Double Hump 1.94 Int 1.50Exh Valve Covers Eldebrock Signature Series Manifold / Induction Eldebrock Performer ESP Chrome 600-cfm Eldebrock Carb. Ignition / Wires Petronics FlameThrower HEI / 8mm Delco Headers Hooker 70 Corvette Exhaust / Mufflers 3inch / Flowmaster 40 Series with 22x 5 Baloneys ChromeTips T R A N S M I S S I O N Year and make 70 Chevy Turbo 350 Converter B&M 2000 stall Trans mods B&M Shift Improver Kit/ Deep Crome Trans Pan 153 Tooth Flywheel Shifter Lokar Shifter B O D Y Body style / Material Step-Side / All Steel Body Manufacturer Chevrolet (Rock Hard) Hood Fiberglass 6 Cowl Induction latch style Grille Stock, Chrome Bed Stock, Steel, altered Bedwood Bodywork Steven & Bryan Lail Painter Paint type / Color Flames Headlights / Taillights Stock / Corvette ZR1 rollpan Outside Mirrors Stock / Chrome Peep I N T E R I O R Dashboard Modified Stock Gauges AutoMeter Monster tach Stereo / Speakers Pioneer / Jenson Full-Range Truck Boxes Air Conditioning Just roll down the window and open the vents Wiring 73 Nova Steering Wheel Grant Classic Style Seats T.B.D Upholsterer Material / Color Black /Yellow Carpet Full Molded Carpeted Floor / ACC Interiors
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
