Questionable
For the 67-87 front crossmembers, I can literally take out the fourteen bolts - three on each bottom side of framerail, four on the each inner side of framerail - and just roll the whole thing out of the way while it's still bolted to the control arms, springs, wheels, brakes, all attached, without any problems or dangers, right?
I can't see why this wouldn't be possible, but thought it would be a good idea to ask first. It looks like the springs aren't going to push things around too much, but ... better safe than sorry, finding out the hard way!
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 02-29-2008 at 12:34 AM. |
Re: Dumb front crossmember question
I believe your right. I haven't done it but taken it all apart and long as no lines are connected like brake lines you should be able to.
Yes you can remove the entire thing as an assembly, no problem.
66 Chevy Stepside tandem project My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902 |
A guy with a truck
You will need to separate the tie-rods or pitman and idler arms too, but yeah, it can be done that way. It will be HEAVY...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
Questionable
Tie rods are off, along with center link. I just need to remove the rubber brake lines where they meet the hard lines at the framerail (and the clips holding the hardlines to the xmember, IIRC). For the sake of safety, just wanted to make sure nothing would come flying back up in my face when I unbolted it, with springs under pressure, et al.
I just want to be able to take the front end, use a bar to keep the wheels straight, and roll it somewhere else in the garage. I have a hoist if needed, but what I don't usually have is an extra pair of hands willing to get dirty :\
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 02-29-2008 at 02:38 AM. |
soon to be bagged64sub
I did when I put a 79 front clip in a 64. Itas not that hard but its harder to roll than what you would think. But I also left the whole steering unit pump and all on it. I just unbolted everything and jacked the rest of the truck up out of the crossmember.
1969 c-10, bagged, Zd, 20" Boyds SOLD! 1964 Suburban COMING SOON ![]() 1965 c-10 long bed 1993 Sierra x-cab 1999 tahoe-4/5 on 22s 2005 Chevy work truck |
![]() Join Date: Sep 2006
I did this a while back. There was no front clip on the truck but the cab was there. You will have to watch the brake lines clipped to the backside of the crossmember. And bagged69c10 is right, it's harder to roll around than you might think.
BRENT ![]() -'68 Stepside Project -'98 Z71 Daily Driver -Enough extra parts to build another truck and a half |
