02-29-2008, 03:20 AM | #1 |
soon to be bagged64sub
Power steering
I am about to build a new frame for my 65 Burban and I was wondering if anyone else has a bagged truck with manual steering. The Sub has the stock manual box and I think it would be easier to keep it. Also can I just swap the manual box for a power steering unit without changing the whole steering up.
1969 c-10, bagged, Zd, 20" Boyds SOLD! 1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726 1965 c-10 long bed 1993 Sierra x-cab 1999 tahoe-4/5 on 22s 2005 Chevy work truck |
02-29-2008, 03:43 AM | #2 |
Questionable
Re: Power steering
i cannot attest to pre-67 vehicles, but on the 67-72 trucks, the gearbox is mounted on teh driver side of framerail (between core support and control arm), and it's as simple as swapping out the gearbox and changing the pitman arm to a diff't style (power and manula pitman arm are diff't).
i realize '65 may not be the same, but ... doubt it's much diff't from 60-66.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
02-29-2008, 06:45 AM | #3 |
Too many projects
Re: Power steering
I have manual steering on my GMC and it's perfectly fine to drive with. I believe on these trucks the boxes swap (bolt hole wise), so you could always add it later.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
02-29-2008, 07:39 PM | #4 |
Re: Power steering
I know that the power box has a part up against the frame that has sets in an indention on the frame so you have to buy the conversion kit from CPP if it were a stock frame. But since Im building my own frame I could put the little indention in when building it but then I would have to buy a power box. Thanks for the help.
