Old 02-29-2008, 04:18 AM   #1
Select
Friday's Toy
Select's Avatar
Motor mounts and towers?
I have a 1987 TBI motor going into a 72 LWB C10. The problem I am having right now is I have normal small block towers and new rubber mount, but the stock exhaust manifolds are hitting the frame when it still lacks about a 1.2 inch to bolt up. My 68 has a big block in it and the mounts are different. What kinds of towers do I need to run in order to get my clearances with the stock manifolds for the 87 350? Should I just run the ram horns and forget it or is there another solution. Right now if they were to bolt up as is the motor is leaning back like the trans crossmember is to low when it isn't.
68 C10, SWB Fleetside with a 454, Turbo 400 and 4.11 posi....Exxon/Mobil loves me.
2009 Jeep Rubicon
2011 Powerstroke FX4 (totaled)
71 C10, SWB Fleet with factory tilt
72 LWB C10, 350 700R4 with factory tilt
Select is offline   Reply With Quote
Old 02-29-2008, 04:46 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Motor mounts and towers?
just slap the ram horn manifolds on there. They flow better anyways.
that or headers
Old 02-29-2008, 07:49 PM   #3
hyarbour
I agree with Longhorn Man. I just dropped an '89 block in mine with headers, they cleared fine.
hyarbour is offline   Reply With Quote
