Old 02-29-2008, 05:33 AM   #1
Lated
Lated's Avatar
I need a measurement
I need measurements from the ground to the highest point on the frontwheel opening on trucks that have been dropped 3.5" in the front and are running 28" tires. I did a 3.5"/4" drop on my truck just over two months ago. I don't think the back actually came down 4" (the stock springs must have been sagging) and the front looks like it came down more than just 3.5". The tires in the before and after pics are the same height (28") if I remember my measurement right from October when I ordered the parts a 5" from drop should have put the top of the wheel opening right on top of the tire but with the 2.5" drop spindle and the 1" drop spring installed the top of the wheel opening is actually about 1" below the top of the tire and now I'm having rubbing issues when I hit potholes or bumps (the tires are 235/70R15). I'm just wondering how much drop I actually ended up with.
“If you don’t have time to do it right now, how will you ever find time to fix it.” - author unknown
'70 SWB Step-Side (More rust than metal)
Lated is offline   Reply With Quote
Old 02-29-2008, 06:50 AM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: I need a measurement
That thing looks good closer to the ground... I haven't gotten to the drop kit on my truck yet so I can't help with the drop question.
Is it a BB truck? It could be just the height of the tire causing issues.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 02-29-2008, 08:13 AM   #3
crazy longhorn
Fabricate till you "puke"
Cant help you with measure......but she shore looks sweet with that nose down attitude crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 03-01-2008, 04:49 AM   #4
Lated
Lated's Avatar
Thanks for the compliments, I like it a lot better the way it is now but I think it either needs to come down a couple more inches in the back or I need to put taller tires on the back. I'm not sure my truck can really even qualify as a SB, it's just a 305. I guess I don't really need a measurement from a truck that has the same drop/tire height, I would just need to know if it has been dropped and how much and what height tire it has and I could calculate the difference. Even just a measurement from the center of the spindle to the wheel opening and amount of drop would work.
Old 03-01-2008, 05:44 AM   #5
corn
Looks more like 5" front & 4" in the rear to me...
corn is offline   Reply With Quote
Old 03-01-2008, 07:20 AM   #6
Hey,I was looking at that old set of wheels`n`tires today on a 4wd Suburban...seriously.You must have sold those to Oldblue60 in Silver Spring.
Old 03-01-2008, 07:29 AM   #7
tcb-1
Nothing to see here.....
tcb-1's Avatar
can't help you either. I know the stock heights I had on my step before dropping was 34" in the rear and 32" in the front. apparently, those numbers are good because LMC has them listed in their catalog.
nice step you have!!! has that old school California rake. me likey!!
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 03-01-2008, 06:11 PM   #8
68Stepbed
68Stepbed's Avatar
Here is a 3.5/4 drop on my 68. I'm running 255/60/15 front and 275/60/15 rear tires. I'll try to get a measurement later.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 03-01-2008, 11:06 PM   #9
Lated
Lated's Avatar
Yes indeedely!
