Need help with getting this stupid passenger window installed
Hi guys and gals..Im having problems getting the used replacement into place inside the door...i got the vent window out that went fine and then i got the old lower frame off the regulator but now i cant get the the new window on the regulaot inside the door...i cant manuver it enough to get it on the rollers...what am i doin wrong here??? help please
"Dixie Destroyer" 71 C10 LWB Fleet Future Blown Prostreet Monster |
Old member
Re: Need help with getting this stupid passenger window installed
Did you take the two screws loose on the backside of the door. The ones that hold the channel into the door. They are at the bottom of the door toward the back of the truck. Take those loose and the roller's will go right in place. You may have to work the window regulator also for it to line up.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
The Older Generation
You might find some tips in the FAQ's. http://67-72chevytrucks.com/vboard/s...d.php?t=262547 scroll down to the door/window section. LockDoc
ok thanks for the replys yall...got it back together finally...had to man handle the regulator to get it to cooperate with me lol
