Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 02-29-2008, 07:29 AM   #1
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Throttle body modification
Since I am replacing the intake gasket, why not make some modifacations along the way. The entire intake was off anyway.
I decidce to remove the air restrictor on the intake plenum.
Hacksaw did a very good job.
If you do this mod, don't grind out the rivets!! If you do, your engine will idle high.
Now, I have to finish the rest of the coolant system so I can start it and drive it!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
