02-29-2008, 08:53 AM | #1 |
Official Track Changer!! woot!
sound deadener
once more, another interior Q for my truck haha
In a week, I plan on taking my truck to my friends house, pulling the motor out to replace all the gaskets and any other things that need to be replaced, sanding and painting the valve covers, master cylinder, power brake booster, A/C unit, and maybe the fender wells. . . .in this time period i have recently considered pulling my seats and such out of the cab and lining everything with sound deadener. I'm just spitballin here so any advice, agreements, arguments, referrals, or help would be tremendous. . .i will post a picture of my interior but frankly. . .if you don't know what the inside of a truck looks like. . .i'm not sure you would be a solid reference for truck interior advice appreciate it all!! Chase
When something breaks, it needs to be fixed. If it breaks again. . . BUY A CHEVY!!!! |
02-29-2008, 09:28 AM | #2 |
Re: sound deadener
Go for it. It took me and my brother a while to do what you just listed because we ended up just buying a new motor over putting the 283 back in and it snoballed out of control. oh and one of these would look great in there you would be amazed at how much better you will feel with a clean looking engine compartment http://store.summitracing.com/partde...5&autoview=sku
ΜΟΛΩΝ ΛΑΒΕ Last edited by straitnate14; 02-29-2008 at 09:33 AM. |
02-29-2008, 09:34 AM | #3 | |
Re: sound deadener
thank ya much, did you ever put deadener in? if so what kind? appreciate it -Chase
02-29-2008, 09:47 AM | #4 |
Re: sound deadener
when my dad did his frame off resto on his 68 GTO he and actualy used ice and water shielding and also did some dyno mat and got great results http://www.graceathome.com/pages/roofingprod.htm
http://www.dynamat.com/
ΜΟΛΩΝ ΛΑΒΕ |
02-29-2008, 09:52 AM | #5 |
Post Whore
Re: sound deadener
I actually haven't got to putting sound deadner in my truck yet but here is a pretty good sound deadner reference article I saved awhile back, thought it might be of interest to you. As far as putting it in there or not there is no way that my interior is going back in the truck without sound deadener, not sure if it is worth pulling the interior to put it in though.
Anyway check out this article, it is probably starting to get a little dated as I bookmarked it over a year ago. http://www.sounddeadenershowdown.com/
Drew '71 Chevy 350/TH350 Hugger Orange Currently just a rolling frame, body work soon to follow!!! Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=212927 Daily Driver: 1997 Chevrolet S-10 with more gears than pistons |
02-29-2008, 10:02 AM | #6 | |
Re: sound deadener
thanks again!! -chase
02-29-2008, 10:04 AM | #7 | |
Re: sound deadener
thanks much -chase
02-29-2008, 11:15 PM | #8 |
Re: sound deadener
I installed Fatmat in my cab. It's still in the building stages, so I don't know the true effect yet. But it took a lot of the hollow sound out of the otherwise empty cab already. I imagine that once the rest of the interior is finished, it'll make a huge difference.
If your considering any of the peel and stick types like Dynamat, check this link http://cgi.ebay.com/ebaymotors/50-Ft...em370024845622 It was hands down the best price I found, and it seems like a good product so far. Easy to install, and sticks very well. 50sf did the back wall, floor, and firewall on my truck. With about a 6"x6" piece left over. Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! |
03-01-2008, 02:38 AM | #9 | |
Re: sound deadener
Definately helps, because price is a huge issue. Thanks for the response and i will definately look into it. Chase
03-01-2008, 08:21 AM | #10 |
Out of the carpool lane.
Re: sound deadener
Thanks Psycho71, that coverage info was very helpful. I thought I'd need about twice that amount. After doing some comparison shopping, I'll be using the same product.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
03-01-2008, 10:08 AM | #11 |
LAIDOUT
Re: sound deadener
I bought 2nd Skin after reading that article. The guy that owns 2nd Skin should buy the author of that article a nice second home in the Bahamas. Can't beat quality testimonials!
I found when I was installing mine that it had an interesting odor, nothing that lasted or that was annoying, but I eventually figured out what it smells like. It smells like the inside of a tanning bed, and don't ask me how I know! |
03-01-2008, 10:12 AM | #12 | |
Re: sound deadener
haha yeah that smell has proven to not be very bad at all but what all did you cover, and how much did you end up using? did 50sq ft cover it?
03-01-2008, 10:22 AM | #13 |
LAIDOUT
Re: sound deadener
I ordered 60sqft and have one piece left so I used about 58 sqft. I did the floor, firewall up to the rounded part, the back of the cab, the roof under the headliner and inside the doors. Doing the doors was a bit of a pain but well worth it.
03-01-2008, 10:32 AM | #14 | |
Re: sound deadener
I see. . .is your gas tank moved or still behind the seat? I have been told that that is a good stereos worst nightmare, an aluminum tank. . .i can understand that being the case so wondering, is yours moved? if not, did you cover it too? Chase
03-01-2008, 11:06 AM | #15 |
LAIDOUT
Re: sound deadener
I moved my fuel tank out of the cab. I built a sub box for four tens to fit where the tank was. If you use the 10"s from Elemental Designs and build the box just right you can still put the seat all the way back. I still need seal the box tight, paint it and mount it permanently. It sorta moves around back there now, .
03-01-2008, 11:26 AM | #16 | |
Re: sound deadener
That looks awesome!! Once sealed and mounted, I'm sure it will sound incredible!!
03-01-2008, 08:23 PM | #17 |
LAIDOUT
Re: sound deadener
Yea I am sending 1000w at those subs, it pounds pretty hard. And with the sound deadner everywhere there is virtually no rattling or tin can type sounds.
03-02-2008, 02:29 AM | #18 | |
Re: sound deadener
Sweet, what about airflow? Right now i don't have a stereo in my truck, but when i drive i hear air whistling everywhere!! Bad weather stripping or something else?
03-05-2008, 08:07 AM | #19 |
Re: sound deadener
How necessary is sound deadener actually? I mean i know it makes a difference,. . .but is it something that can wait?
Chase
03-05-2008, 09:18 AM | #20 |
LAIDOUT
Re: sound deadener
I would say it depends on whether your interior is all removed or not. If you need to pull the seat and carpet to do it, you could do hat when it is convenient.
03-05-2008, 09:22 AM | #21 | |
Re: sound deadener
Ok. . .thanks man. . .it can wait, lol
