Future TOTM Winner
Has anyone ever added a factory style dome light (or two) to a double wall top? If so, where, and how did you run the wire? Any pics?
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
Its lookin' like a Blazer!
Re: Doube wall dome light???
Something I've pondered on are those new LED push style lights. I think they are closet lights or something. I know my LED flashlights last forever before having to replace the batteries. The light produced by them blows the old factory GM stuff away..... Just a thought. Best part is no wires to run, lol....
SKINNY TIRES RULE!
I think running the wires is the issue. You might be able to route out a channel or surface mount the wires in some way.
As for alternatives, I thought that running the LED strip lights under or along the bed rails. That way, there would still be lights in the truck when the top is off.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
#4 | |
Roof: Bad. Sky: Good.
![]() Join Date: Jul 2007
OleSenna |
#5 | |
![]() Join Date: May 2007
http://www.rallylights.com/hella/Ova...tesy_Lamps.asp he also got some of these from the same place "I also bought the Hella CE lights; and the Terra Map lights; plus driving and fog lights from this company. " - quote frome Jfortner. I havn't had a chance to talk to him about how he implemented them or how it all worked out. Also I must say I haven't puchased anything from this company or tried these lights. I just thought it might give you some ideas. Hope that helps - Jason
- Jason ![]() ![]() |
![]() Join Date: Dec 2002
My first blazers double wall top had a small gun rack/fishing pole holder
mounted in it. They used plastic plugs to mount the screws meaning hollow in that area. so I would think you could easily get one light in. Putting a second one towards the back might be a problem if the top has any real supports. If you could find a messed up top and get a look you would know for sure. Anyway I am redoing the floor pans in my truck. I bought the light set up for a single wall. I plan on running the wire under the floor or through the rocker box. If I knew how a true one was run I would do it like that. The wire has to run through the area that is the first stake pocket on a pick up bed |
#7 | ||
Future TOTM Winner
I have an old broken top. I think I will do a little exploring through its insides.
Rods
![]() Join Date: Nov 2002
hmmm i am in need of an old broken top.......I use old chey reverse lights in the side panels of my cst. they look factory clean and are wired into my underdash lights
#9 | |
Future TOTM Winner
I'm curious, what are you hoping to do with a broken top??? Make a half top or do you need a patch piece to fiberglass into another top? Either way, maybe we could work a deal/trade. PM me if you have anything interesting! ![]()
What about replacing the rear view mirror with one that has lights built in?
I know you can buy them after market but I forget what cars/trucks had em factory. |
#11 | |
Future TOTM Winner
Oh yeah, I forgot the "L" in "double" ![]()
![]() Join Date: Nov 2007
I don't think they're cheap. And you'd need to run electric up the windshield frame.
#13 |
SKINNY TIRES RULE!
I've only seen one of the proper era factory mirrors for sale on ebay in the past and it when for a mint! My '94 Mustang Convertible had lights in the mirrors and I'd assume a lot of other convertibles do as well.
#14 |
SKINNY TIRES RULE!
#15 |
http://www.nifty-stuff.com/mini-tap-light.php
there ya go! lol...actually that's not a bad idea...you COULD modify it to look more like it belonged. also, i know the tapping part is lame but consider that on most cars, dome lights and/or maplights turn on by clicking/tapping them. OR http://www.autobarn.net/syldotit.html
'72 K5 CST Blazer 4x4 in perpetual progress '96 2dr Tahoe 4x4 daily driver, Black Bear Performance tune, 285-75-16 Nitto Grapplers, Magnaflow muffler, K&N Air filter, Bilstein Shocks.........E-fan, DT Tri Y or Pacesetter LTs coming soon Last edited by Blizz; 03-02-2008 at 12:57 AM. |
#16 |
