03-01-2008, 02:43 AM | #1 |
Ignition switch spacer thingy
I have a 67 LWB that needs the ignition switch spacer that sits behind the dash on the ignition switch. I guess this style was only on the 67s. Does anybody know where to get one? LMC shows it in their catalog but they don' carry it anymore.
Thanks, JD |
03-01-2008, 02:49 AM | #2 |
Re: Ignition switch spacer thingy
I may have one around the shop. I know I have the GM part number. I will look tomorrow. They were used from 67-72 on C-K models & several years after that on vans. Do you have the cone shaped ring that goes on the front of the dash? georgec2434@yahoo.com
03-01-2008, 02:54 AM | #3 |
I think he is talking about the spacer behind the ignition switch. I also think the bezels on the front are different for a 67 too.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
03-01-2008, 03:02 AM | #4 |
Would the 67 be different then the 68 up? I,ve had a lot of them out & seems like they were the same.
03-01-2008, 04:26 AM | #5 |
That's right, it's Copper!!
The early 67 is different than the late 67 68 up.
03-01-2008, 08:00 AM | #6 |
I "think" I have the bezel an the space for the early 67- they are smaller and different from the later stuff, pm me if interested- bezel is OK for driver- but has scratches.
