Old 03-01-2008, 03:10 AM   #1
Deathtrapgarage
Lash adjustment for 235 c.i.
Having a hard time finding a manual on my truck needing to tune it up and adjust lifters, needing to know if anyone has any idea of the lash adjustment. 235 c.i. 1962, thanks alot.
Deathtrapgarage is offline   Reply With Quote
Old 03-01-2008, 10:53 PM   #2
malibu795
malibu795's Avatar
Re: Lash adjustment for 235 c.i.
usually it is in the neighborhood of .012-.016 cold
would like to know the spec as well
-A DAM WILD MAN-
59 apache pannel truck 38 I-6/sm420
79 malibu wagon 305/t56
02 2500hd duramax/allision 1/4 13.82 @100 mph efi live and built tranny
500hp 383 on the engine stand
U.S. Navy 2000-Current
Peace through Superior Firepower
Horsepower = Condom.....I would rather have it and not need it than to need it and not have it
malibu795 is offline   Reply With Quote
Old 03-02-2008, 08:04 AM   #3
Fred T
Cantankerous Geezer
Fred T's Avatar
Spec calls for .006-.013.
To adjust lifters on a 216, 235 or 261, here is the correct procedure.
First- Your valves are laid out this way- from front to back:
#1 exhaust
#1 intake
#2 intake
#2 exhaust
#3 exhaust
#3 intake
#4 intake
#4 exhaust
#5 exhaust
#5 intake
#6 intake
#6 exhaust
This procedure can be used on either Hydraulic or Solid lifters. Just know which kind of lifters you have* for final adjustment.
Turn the crank (by hand) until #2 cylinder intake valve (look above- it is the third rocker back from front) is observed to start opening (that means the rocker is pushing the valve down and open). Now turn the engine slowly and notice that #1 cylinder exhaust (first rocker)valve will also start to open. Continue cranking until #2 cylinder's intake valve is wide open, AND then notice that #1 exhaust valve is also coming to the wide open position. (#1 exhaust valve lags a little behind #2 intake valve) Continue turning (slowly) until both valves are wide open.
With these two valves wide open adjust: Solids: intake-.006. exhaust-..013 (special note: if this is 1 1/2-2 ton truck exhaust is .020) Hydraulics: adjust until just touching and no or very little wiggle of rocker can be felt. Adjust: #1 cylinder intake #2 " exhaust #3 " both #5 " intake #6 " exhaust.
Now turn the crankshaft one full turn until #5 cylinder intake is observed to start open. Lagging behind will be #6 cylinder exhaust. Continue turning the crank until both of these valves are wide open and then adjust: #1 cylinder exhaust #2 " intake #4 " both #5 " exhaust #6 " intake.
Your engine will now be ready to start. Let it idle for 30 minutes till completely warm and do the final adjustment.
It has been brought to my attention that I didn't give the final adjust for hydraulics -- Tighten down until no noise is heard (use a section of hose to your ear and to the tappet if needed) then tighten one(1) complete turn.
* If you don't know whether you have solids or hydraulics -- Pull the rocker cover, loosen one rocker, pull the push rod, drop the side cover off, pull that lifter. Now take it to a machinist or mechanic and ask him which it is. OR, once you have the lifter in hand look to see if it has a hole in the cup (top) end and will push down in the center, if it does, it is hydraulic, if not it is solid.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 03-02-2008, 08:07 AM   #4
kdrodworks316
KOFFIN DRAGGER
kdrodworks316's Avatar
finger tight, then half a turn
kdrodworks316 is offline   Reply With Quote
Old 03-02-2008, 08:08 AM   #5
kdrodworks316
KOFFIN DRAGGER
just kidding, thats really bad advice, dont do it that way. Freds got you on track.
