03-01-2008, 07:12 AM | #1 |
Custom air tanks
Hey guys! I was wanting to make some custom air tanks for my truck. I am not sure how thick of material i should use. I found some 5" OD dome ends that were 14g which i thought would be plenty thick but wanted to get some opinions before i order anything. So do you think 14g is safe to use?
Thanks Josh
(Project truck) 1970 C10 under complete transformation My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
03-01-2008, 08:04 AM | #2 |
Too many projects
Re: Custom air tanks
subscribed for answer
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
03-01-2008, 08:15 AM | #3 |
Questionable
I saw a recent article in Truck Builder mag where someone boxed in their framerails to turn them into tanks. Very cool concept, very custom, and very sweet way to hide your tanks!
(May not help, but it's a cool idea!)
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
03-01-2008, 08:31 AM | #4 |
I am doing kind of a custom setup. I am using the round tubing in my frame as my air lines. I wanted to have no air tanks and just the volume of the tubing as my tanks but it doesn't equal out to be enough. So i am going to build some custom tanks that will go in the middle of the my frame and plum them into my round tubing. I think it will look sweet but we will see.
Josh Ps. I was told that you shouldn't use square or rectangle tubing as tanks because of the air pressure will ballon the steel. It has to have an even pressure all the way around or it will ballon.
03-01-2008, 08:42 AM | #5 |
Questionable
/me tries to picture 3/16" steel balooning
03-01-2008, 08:50 AM | #6 |
I was just saying in general that someone should use round over rectangle. I don't think 3/16 would ballon with only 180psi.
josh
03-01-2008, 09:26 AM | #7 | |
03-01-2008, 09:45 AM | #8 |
Questionable
i wondered about that too - they actually did this "tubing as air source" trick on Extreme 4x4 on one of the Toyotas they back-halfed, IIRC. i wondered about the same thing, i don't think drier valves would really help.
03-01-2008, 10:15 AM | #9 |
Make a square or rectangular air tank out of 3/16" and put 180 psi. in it.... it might surprise you!
Would it work... yea, but it will bulge. Over time (long period) it will fatique and eventually stress crack and leak. As for moisture... it's the constant enemy of any air suspension system. The round tubing wouldn't rust and or corrode any faster than the inside of the air tank. It would ve beneficial to coat the inside of the tubing with something to protect them... helping to minimize corrosion/rust. 14 gauge should work fine... it would be nice to find some in 10gauge though.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
03-01-2008, 10:37 AM | #10 | |
03-01-2008, 08:33 PM | #11 |
I never really thought about the moisture. So lets put our heads together and come up with something that will work. If you coat the inner liners of the round tubing would help but when i weld the tubing together it will most likely burn the coating off where the weld is. Is there anything else that i might be able to do?
Josh
03-01-2008, 09:35 PM | #12 |
they have a product that is used to coat the inside of gas tanks. iv used it on a rusted atv tank before. just do your welding then pour this stuff in and coat the inside of your tank.
03-01-2008, 09:37 PM | #13 |
03-01-2008, 10:44 PM | #14 | |
The large portion of the tubing will remain coated after you welded... just the smaller area affected by the heat at the joints would burn off. Besides, Josh, you can just build another chassis if it starts to leak!
03-02-2008, 06:56 AM | #15 | |
Not a bad idea about the braided lines. I wonder if i would be able to get it to make the turn to come out of the round tubing. Josh
03-02-2008, 06:58 AM | #16 | |
Josh
03-02-2008, 09:43 AM | #17 |
Hollister, CA.
Keep in mind you can always use aluminum. In fact, they manufacture luminum air-tanks for air-ride.
This might be an idea. You will be running filters, right ??
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
