03-01-2008, 06:53 PM | #1 |
power steering install
i know this is posted alot and i looked at a ton of previous topics, but i have a question about the steps you take to get the power steering working properly after everything is installed. i am planning on using this as a guide:
http://67-72chevytrucks.com/vboard/s...d.php?t=216886 but at the end, it is not real clear on how to start using the power steering setup. i bought a used one off here a few months ago and plan on installing it this month. |
03-01-2008, 08:17 PM | #2 |
Active Member
Re: power steering install
Joe, what do you mean you say "how to start using the power steering setup.."
Are you referring to something in the actual installation process or adding the power steering fluid and priming the pump after the installation? |
03-02-2008, 01:41 AM | #3 |
Questionable
basically, this is what i understand, although i HAVE NOT done it yet.
you can supposedly burn up a new gearbox if you don't take proper precautions after installing it. i hear - and someone can chime in, i hope - i hear once you install the new, empty, no fluid inside gearbox, you should lift the front end of the truck off the ground so the wheels are not touching. DO NOT STEER YET. Fill the resevoir with fluid and leave the cap off. Start the truck. Turn the steering wheel lock to lock, then turn off the engine. Go fill the resevoir up to the fill line again, then repeat. Top off the fluid afterwards, put the cap back on and then drive it around. Again - this is just what I've HEARD (and read) around here. Don't take this as the end-all be-all example of what to do. I know how to upgrade to PS, but haven't actually driven on it yet
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 03-02-2008 at 03:28 AM. |
03-02-2008, 02:04 AM | #4 |
That's the way my brother and I done it.
68 C-10 Custom LWB 307 V8 Lexington,NC davideowens@lexcominc.net God Bless America |
03-05-2008, 08:37 PM | #5 | |
ok, thanks for the info, this is very helpful!
03-05-2008, 09:06 PM | #6 |
Questionable
When digging through my thread subscriptions, I found this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=251657
It talks about how to properly fill up and prime.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
03-16-2008, 05:44 AM | #7 |
so i got the gear box out today, not to bad. but the puller i got (oem) doesnt fit around the other side of the pitman arm. it is too small. i had no problem getting it off the gear box. how do i get this off? also i compared the manual pitman arm to the power one and they look identical, and i asked at the auto store if they had a different one for power and they said they were the same part #. why do you say to change it?
03-16-2008, 10:03 AM | #8 |
Questionable
I bought a puller from the local auto parts store - $8.
I say change the pitman arm, because mine was drastically different between power and non-power. I have no idea what the guy is talking about, unless you're using a non 67/68 truck. It's really important to understand that there appear to be some differences between 67-68, 69-70 and 71-72 trucks. Be wary of this any time you're dealing with parts.
03-28-2008, 08:58 PM | #9 |
so heres where i am at so far. I got the gearbox mounted, but it seems i have the power steering pump brackets for a long water pump. i have a short on there now (this is a 71 c10). now, i had a 1 groove crank pully, but i switched that with a 3 groove. the fan pully and the crank pully do not line up now. if i get a long water pump, will they line up then? or should i get the short water pump brackets and a crank pully that lines up with the short water pump? will the long pump fit (meaning the fan will have enough room and will not hit the radiator)?
03-29-2008, 08:35 PM | #10 |
anybody?
