03-01-2008, 10:58 PM | #1 |
Its Magically Delicious
cranks but wont start
Up until today i was having a intermediate starting problems .. it would start then imediently die ... like 1/2 second after i let go of the key ....
now today it cranks but wont start ive: checked and changed fuel filter replaced ignition switch cap and rotor are new check , tightened and cleaned grounds Ran a new wire from solenoid to + on coil (old was cracked and super brittle) what do you suggestion next
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
03-01-2008, 11:44 PM | #2 |
Re: cranks but wont start
set the dwell on the points and clean and gap the sparkplugs
03-01-2008, 11:52 PM | #3 |
Active Member
...checked and changed fuel filter
replaced ignition switch cap and rotor are new check , tightened and cleaned grounds Ran a new wire from solenoid to + on coil (old was cracked and super brittle) ----------------- If you have points check that first as cdowns mentioned. Make sure you're getting fuel to the carb.... If you are, check to make sure you're getting spark to the spark plugs. If you're getting both and still doesn't start, then check timing. Check compression. |
03-02-2008, 12:23 AM | #4 |
my bro swung by for alittle bit .. and watch spark pjug while i cranked it .. and i have no spark
i think its time to remove the pertronix ..... i can't remember how to hook the old points back up though ... bad short term memory help !!
03-02-2008, 12:26 AM | #5 |
have you checked your coil. to see if it's working.
03-02-2008, 12:33 AM | #6 |
To The Levy
well, I got rid of points along time ago, the wire on the starter , is for bypass, it allows full voltage while cranking to the coil, and after its started it than gets power from the resistor wire , if this resistor wire is broke or unhooked , you may want to look there, try bypassing it all together , for the time being for testing purposes, just run you a 12v wire to pos. coil and see if it runs, if it doesnt your problem lies elsewhere, if it than starts and stays running, you know whats up....
if no spark on a point type system , its pretty much cut and dry, gotta have power to coil pos. side with key on or running, the points are only a switch to allow the coil to build and than produce power out the center term. to cap and out to plugs..... good luck , keep us informed... |
03-02-2008, 12:36 AM | #7 |
Ditch that Pertonix I. Total crap;http://67-72chevytrucks.com/vboard/a.../t-173315.html
The new ones may be better.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
03-02-2008, 12:43 AM | #8 |
you coil reads 1.3 ohms so its good ....
03-02-2008, 12:45 AM | #9 |
is the resistor wire brown or yellow ??
03-02-2008, 01:06 AM | #10 |
Son of a gun
There is no way to test a coil to make sure that it is good. A bad coil will more than likely work just fine until it heats up, then the internal insulation melts shorting out the windings, and stopping you dead in your tracks like somebody turned off the key. It usually takes about 30 minutes of running to make that happen. then after the coil cools down it'll restart and run fine for another 30 mins. I do not think that your problem is your coil. After it dies does it start back up? Sounds like something is loose or bad in the ignition cuircut. Could be a loose wire to the coil, from the ignition switch, or could be a bad ignition switch. Edit: I just read the part about the petronix I would definetly toss that garbage, and put in a set of points...that would be my first attempt to fix the prob.
Bill BEATERS ARE NEATER Last edited by Bus Ted Knuckle; 03-02-2008 at 01:11 AM. |
03-02-2008, 01:27 AM | #11 |
ignition switch was already changed out this morning ... all connection are tight ....
had the battery tested ... 12.5v 300 amps .....
03-02-2008, 04:08 AM | #12 |
Step Brother
do you have 12 volts on the + side of the coil?
03-02-2008, 04:43 AM | #13 |
ill find out later .. its pouring down rain right now
03-03-2008, 12:13 AM | #14 |
new battery didnt help ...
with the key one i DONT have 12v while reading between + coil and ground what should i check next ??
03-03-2008, 01:19 AM | #15 |
i have spark now .... the engine sound like it wants to start ..... also when i let go of the key .. the starter runs on for a second or 2... kinda winding down sorta .... any thoughts
03-03-2008, 02:17 AM | #16 |
To The Levy
maybe its flooded now. quit pumping it , or pull a plug and look at it, wet or not?
I have changed many coils for breaking down cold too, you need a higher demand of spark to light a cold mix, more likely fail hot though. changed many coils on chryslers for weak spark or no start on cold start, I know this is no chrysler , but just a word of thought....... |
03-03-2008, 02:58 AM | #17 |
i changed the plugs and it fired up.... sweet relief
now to drink some beer
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. Last edited by 71-longbed; 03-03-2008 at 02:59 AM. |
03-03-2008, 05:56 AM | #18 |
Step Brother
GREAT, I'M GLAD IT FIRED UP!!
03-03-2008, 06:20 AM | #19 |
i am too .. starts really nice and quick now ... pertronix blows
who makes the best electronic conversion ??? mallory, crane, accel ??
03-03-2008, 07:23 AM | #20 |
Step Brother
I Would Go With Factory Conversion.
03-03-2008, 07:49 AM | #21 |
You can usually find an HEI for a good deal. They are mostly bullet proof, so I just carry an extra module like I used to with points. I now make it my first upgrade on any vehicle I get or work on. The only thing you need to worry about is getting a full 12v to the HEI and not the 7~8 volt ballast resistor lead used on the points. For me it just replaces another consumable (points, condenser) from the equation.
Shawn
-- Shawn '67 Short Step '70 Short Wide |
