Runs well straight
but then it then stalls out when you turn any answers?
Active Member
![]() Join Date: Jul 2007
Re: Runs well straight
If it only does it when your turning the float level adjustment in carb is the first thing that comes to mine. Not sure what else may cause that problem
I would also say float level is set too low. I would look there first.
![]() Join Date: Dec 2006
Then if that's not it,look for a loose wire flopping around in the distrib (points type) or elsewhere in the ign. but probly the float or blocked fuel flow. Does it run good straight under full throtttle?
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
Havent tried it full throttle yet, I am in base housing and live across the street from an MP dont need that non sense. If i am in the driveway and i push the pedal all the was down it sounds fine
Step Brother
![]() Join Date: Sep 2007
when you turn do you put your foot on the brake pedal? if your brake booster is losing vaccum it would cause it to stall.
It just need the adjustment I did a quarter turn on it and it runs like a champ sorta
