03-02-2008, 05:49 AM | #1 |
picked up a '67...now ive got some questions
i posted a thread a few days ago about a 67 c10 i was looking at. i ended up buying it, and now theres a few things im gonna fix on it and had some questions about them.
it needs new hood hinges, because back of the hood sits up a little bit once the hood is closed. i think the springs are probly worn out but im not sure. are 67 hinges the same as the later 69-72 style fenders use? i didnt look at them to close yet. AND.. it has the aluminum slot rims on it from the 70's dont get me wrong i kind of like em, but i have some stock 15" wheels from a 69 K10 and i was thinking about repainting them white and putting them on here. havnt decided yet i just wondered if the 4x4 rims will be the same. and lastly, the rear end in this thing has had the spider gears welded all together. so it doesnt go around corners worth a sh*t. and im sure if i keep driving it this way somthing will break, it squeels the tires pretty good around tight corners. i know ive heard 67 rear ends are not as wide as the later ones, so i wanted to know all the details on the diffrences in the earlyer and later 12 bolts befor i go looking for another rear end. or i might just try and find a carrier and reuse the gears. |
03-02-2008, 06:24 AM | #2 | ||
Re: picked up a '67...now ive got some questions
03-02-2008, 06:37 AM | #3 |
I am a Referee of life.
What you have is sometimes called a Lincoln Locker.It comes from the welder by Lincoln.They are not street friendly or much use for most regular driving.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
03-02-2008, 06:46 AM | #4 |
1972 Chevrolet SWB
LongHair is right,even though the hinges wear,with the rears sticking up after closed is a real simple way to fix that with a little adjusting of the hinge/fender mounts.
My New thread with pics (not my build thread yet.) http://67-72chevytrucks.com/vboard/s...46#post2573646 1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project. 1980 Camaro Inherited when father passed,68K Miles 2003 Ford Mach1 FUN as Hell!! 2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot) 2004 Dodge Ram HEMI 10" lifted on 37's and 2wd. |
03-02-2008, 06:47 AM | #5 |
i know sometimes the hood hinges need adjusted, but wanted to atlest ask if the hinges are the same if i do end up needing to find other ones
and yes, i know the rear end is not a good thing to leave the way it is. it is number one on my list of things to fix on this thing. why do you say i shouldnt reuse the ring and pinion? even if whoever did the custom job to the spider gears didnt remove the ring gear from the carrier what will that effect? will the weld splatter mess with somthing? |
03-02-2008, 06:56 AM | #6 |
The Older Generation
Here's the procedure posted by Huck: To get the back down with existing hinges---open hood----loosen the three bolts that attach hinge to fender (both sides). Now push the hood up till the hinges stop moving, ---now push it open a bit more to preload the hinges. Tighten hinges. (two people make it a lot easier--hehehe) now carefully lower the hood--this may take a few adjustments to get it to sit just right (height wise). You may need to adjust the hood front to rear to allow for proper clearance with the cowl. LockDoc
03-03-2008, 01:47 AM | #7 | |
The real point was that you will have to replace the carrier, which is going to require a gear set-up. For no more than the gears cost, I wouldn't spend the money to set-up a set that are not only used, but likely abused by the welding. |
03-03-2008, 01:56 AM | #8 |
Rice Killing 101
mas rapido replacin on that or ur gonna have a bad time
distrubin the peace since i got the thing and broke the origianl radio on 95.5 classic rock Ride: 1968 c20 lwb 327(orig motor)/np435/eaton 4.10 w/posi puttin in a 496 rebuilding trans need to rebuild diff :| need to start takin pics and start a project thread |
