Old 03-02-2008, 06:00 AM   #1
umwtnt
umwtnt's Avatar
Widest wheel width on 71 fleetside
I am looking for information from others on the widest wheel you have installed on the rear. My measurements indicate I should be able to mount a 12 inch wide rim with 7 1/2 inch backspacing with 15 in wide tires but I am looking for advice before committing. Thank you
umwtnt is offline   Reply With Quote
Old 03-02-2008, 06:06 AM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: Widest wheel width on 71 fleetside
Is it gonna be lowered? Airbags or coil?
(Airbags tend to give side to side play)
I know 10" is no problem at all, for 12"
you may need to widen the rear tubs.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 03-02-2008, 06:08 AM   #3
umwtnt
umwtnt's Avatar
That's an important question, yes I am bagging it. I already have the tubs and have cut the bed for maximum fit.
Old 03-02-2008, 09:08 AM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
I was planning nearly the exact same setup. You should have room to spare if you widen the tubs to the framerails...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 03-02-2008, 02:56 PM   #5
SCOTI
SCOTI's Avatar
At one time, I had 15x14" custom back-spaced steelies w/a stock length 67/8 12-bolt truck rear (coil suspension). The bumpstop on the outside of the framerail had to go & obviously the tubs were stretched, but it required no frame modifications.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-03-2008, 06:53 PM   #6
umwtnt
umwtnt's Avatar
Thank you for your reply
