Old 03-02-2008, 07:02 AM   #1
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Edelbrock 14054 Used Super Nice Low Miles
Edelbrock 600 Endurashine, was purchased in 2007, driven to one car show.
To small for the motor it was on, replaced with a quick fuel 750.
Includes the chrome plated fuel line which is not include when you buy the carb new.
$265.00 plus the ride, that is a savings of over 100.00 from a new unit.
This comes with the box and instructions.
I take pay pal
A carburetor dyno-matched to today's intake and cam designs.
Edelbrock's Performer carburetors feature two-piece, all-aluminum construction for cooler operating temperatures and less warping. There are no gaskets below the fuel bowl level for fewer leaks, and no plastic parts or power valves to blow out. The carbs use easily changed metering rods for precise tuning, and the primary venturi booster is a bottom-feed design for smoother acceleration and better drivability. Also included with every Edelbrock carburetor you will receive a owner's manual. These manuals consist of two sections; Section 1, Theory of Operation and tuning procedures which will help you be prepared to develop your own individualized calibration. Section 2, Tuning procedures will take you through a step-by-step procedure that will enable you to achieve a desirable calibration. For added ease of tuning, a Calibration reference chart for your model of carburetor will be included.
Brand: Edelbrock
Product Line: Edelbrock Performer Carburetors
Part Type: Carburetors
Part Number: EDL-14054
Number of Barrels: 4
Carburetor Flange: Square bore
Choke: Manual
Fuel: Gasoline
Secondary Type: Air valve
New or Remanufactured: New
Fuel Inlet: Single
CFM: 600
Carburetor Finish: EnduraShine
Ford Kickdown: No
Throttle Linkage Type: Universal
Quantity: Sold individually.
Notes: Moderate street high performance, street and towing.
Carburetor, Performer, 600 cfm, 4-Barrel, Square Bore, Manual Choke, Single Inlet, EnduraShine, Each
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 03-02-2008, 08:04 AM   #2
berencam
berencam's Avatar
Re: Edelbrock 14054 Used Super Nice Low Miles
good price, mabee if its still there in a couple weeks i might be interested gl selling.
69 chevy c10 350 3 speed manual wood bed build thread here r.i.p.
70 c10 auto 350 build here
berencam is offline   Reply With Quote
Old 03-05-2008, 08:06 AM   #3
1968SWBBigBlock
Active Member
Ttt
1968 SWB
