03-02-2008, 07:48 AM | #1 |
Ephesians 2:8
79 LWB C-10 Big 10 axle flip ???
I am wanting to lower my 79 C-10. It is a Big 10, so it has 8 springs per side. How far is it going to lower the rear? 5 or 6?
My biggest concern. Would I have to notch the frame? It being a heavy half, I wondered if I would get away with it? Anyone done this to a heavy half before? What about up front, if I did a 5 and 5 drop, what would be best up front? 3" spindles and cut springs? lowering springs? I have had this truck 10 years, and it has sat like a 3/4 ton to long LOL! It already sits 2" higher than my brothers standard 1/2 ton 77. Any thoughts? Thanks, Brad
72 Suburban making it mine My 79 C10 story 79 C10 LS swap 94 LS swapped Daily Driver Tahoe Limited Instagram - @piersonclassics 83 K20 Farm Truck Build |
03-02-2008, 09:41 AM | #2 |
1972 Chevrolet SWB
Re: 79 LWB C-10 Big10 axle flip ???
Most standard axle flips are 6" roughly as the axle tube itself is 3" plus the thickness of your main usual 3 leafs.If you have 8 leafs and you flip the axle to on top of the leafs you may get between 7-8" alone out of just that. Many flip kits come with either shorter or longer than stock shackles to custom tailor for more or less drop with the flip.
My New thread with pics (not my build thread yet.) http://67-72chevytrucks.com/vboard/s...46#post2573646 1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project. 1980 Camaro Inherited when father passed,68K Miles 2003 Ford Mach1 FUN as Hell!! 2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot) 2004 Dodge Ram HEMI 10" lifted on 37's and 2wd. |
03-06-2008, 02:48 AM | #3 | |
6.0 powered square
Re: 79 LWB C-10 Big 10 axle flip ???
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
03-06-2008, 03:04 AM | #4 |
I Would Buy Drop Springs For The Front. I Tried And Cut Mine The First Go Around And It Rode Like Crap
03-06-2008, 09:43 AM | #5 |
6.0 powered square
I did the same thing I cut a coil off and my truck bottoms out all the time, so I'm tired of it some I got some 3inch drop spindles and 2inch coils and drop shocks, I hope it will drive better I just need to grind on the caliper and double check every thing before I take it for a drive
03-06-2008, 09:44 AM | #6 | |
I did 3" spindles & cut 1-coil & I also have B.Tech shackles in back. You can live w/o the c-notch w/just the flip but it might occassionally hit. Flip, shackles & no notch.... you'll hit quite a bit more often than you like.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-06-2008 at 09:44 AM. |
