Master Brake Lines ???
I've searched this question and think I found the answer, but just want to make sure.
Is this right for a 72 C-20 with power disk/drum brakes? The line from the front resivor of the master feeds the rear brakes and the line from the rear resivor of the master feeds the front brakes which is just the opposit for a C-10. Rob |
Re: Master Brake Lines ???
yes, the c10 and c20 front and rear resoviors are oppsosite, i cant remeber which way but i foung out my K10 has a K20 master cylinder and proportioning valve the hard way!
Thanks, because I ordered the lines and went to put them on and the only way they would work is if they crossed each other.
I was begining to get a little P!$$ed. Rob |
