What is the cost for baggin?
I'm getting a standard lowering kit for my 64 c20 lwb (3" front, 4" rear) but I saw a sweet '70 longbed sitting on the ground front and back today. Those of you who have done this what is the realistic price of getting my frame on the ground; including everything (i live in an apartment so labor would have to factor in.) I know I the prices will be all over the board but I just want a ballpark. Thanks!
Wheelin' and Dealin'
Re: What is the cost for baggin?
you can select all your parts for a custom kit for pretty cheap here:
http://*****************/custom.php
1965 Chevy c-10 fleetside long bed with 06 gto LS2/T56 inside ![]() Porterbuilt Extreme front and rear 12bolt w/ eaton tru-trac 4:11 gears ![]() ![]() my build thread: ![]() http://67-72chevytrucks.com/vboard/s...=1#post2601700 |
Chevy Truck Addict
![]() Join Date: Aug 2006
If you want to get your frame on the ground, there will be a lot more work than just the airbag system. You would need to install a step notch in the back. Your inner fenders and wheel tubs would need to be modified and/or removed. The bed of the truck would have to be raised, etc, etc, etc...
If you wanted to install bags and slam it to within 6-8 inches off the ground, you would only need to have a c-notch installed, replace your coil springs with air bags, run some air line and find a place for your tank and compressor. To start with, you could even eliminate the tank and compressor and install schrader valves to raise and lower the vehicle. You would have to inflate/deflate the system manually but I have seen 12V 200psi portable compressors for under 200 bucks that you could use out on the road and avoid having to stop at a gas station. To answer your first question, you could probably buy a complete system with bags, brackets, c-notch a small tank and entry level compressor for under $1500.
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . |
Hollister, CA.
![]() Join Date: Sep 2006
Just to give you an idea of labor.....I would charge a board member anywhere from $500-1000 labor to install a "basic" kit.....custom c-notched and other work would be extra.
Anyone else would be $1000 on up for a "basic" install. I'm sure you could find someone in town or Fresno to hook you up. Otherwise, come see me !! ![]() - - ![]() - - ![]()
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by ChiefRocka; 03-03-2008 at 05:14 AM. |
ChiefRocka- How good of luck are you having with the Viair 480s? I have been seeing them a lot recently. I have 2 380s on my S-10 and have been thinking about a upgrade.
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=269019 Petitioning *No Regrets* MD/WV |
John, that's quite the watts linkage!
Greg 64 GMC Suburban - 283, NV3500, 14 bolt 77 C10 swb - 292, SM465, 12 bolt |
#7 | |
Hollister, CA.
The 380 lists a 100/55% duty cycle....while the 480 is 100/50% duty and is 3 lbs heavier. The 480 has a different head...with a tad more CFM I have heard some people snapping the piston rods (480's), but nothing with my customers thus far. Here are some specs: 380C Air Compressor (P/N 38033) 12-Volt Permanent Magnetic Motor Duty Cycle: 100% @ 100 PSI, 55% @ 200 PSI Max. Working Pressure: 200 PSI Amp Draw: 16 Amps Min. Ambient Temp: -40° F Max. Ambient Temp: 158° F Dimensions: 9.00 L x 4.00 W x 7.00 H Net Weight: 8.00 lbs. 380C Tank Fill Rates 2.5 Gallon Tank Fill Rate 0 To 145 PSI 3 Min. 48 Sec. 0 To 200 PSI 6 Min. 10 Sec. 110 To 145 PSI 1 Min. 12 Sec. 165 To 200 PSI 1 Min. 40 Sec. 5 Gallon Tank Fill Rate 0 To 145 PSI 8 Min. 35 Sec. 0 To 200 PSI 14 Min. 45 Sec. 110 To 145 PSI 2 Min. 42 Sec. 165 To 200 PSI 3 Min. 30 Sec. The 380C is a truly-rated continuous duty, 12-volt, 200 PSI compressor. It is capable of filling a 5-gallon tank from 165 PSI to 200 PSI in 3-1/2 minutes consistently, while never pulling more than 16 amps of power (@13.8 volts). It is the choice for those who wish to keep the strain on their vehicles charging systems to a minimum. Features include a standard Ό stainless steel braided leader hose with inline check valve and insulated wiring for simple installation. *Must be used with a 200 PSI or lower pressure, non-adjustable pressure switch when used with an air tank. 380C Performance Data PSI CFM A bar LPM A 0 1.49 8 0 42.0 8 10 1.17 10 1.0 32.5 10 20 1.13 11 2.0 31.0 12 30 1.09 12 3.0 29.0 13 40 1.02 13 4.0 27.0 14 50 0.99 13 5.0 26.0 14 60 0.95 14 6.0 24.5 15 70 0.92 14 7.0 23.0 15 80 0.88 14 8.0 21.0 15 90 0.85 15 9.0 19.0 15 100 0.81 15 10.0 16.5 15 110 0.78 15 11.0 15.5 15 120 0.71 15 12.0 14.0 15 130 0.67 15 13.0 12.5 15 140 0.60 15 14.0 11.5 15 150 0.57 15 160 0.55 16 170 0.51 15 180 0.48 15 190 0.44 15 200 0.40 15 *Supply Voltage: 13.8 Volts [click photo to enlarge] 480C Air Compressor (P/N: 48040)-Pewter (P/N: 48043)-Chrome 12-Volt Permanent Magnetic Motor Duty Cycle: 100% @ 100 PSI, 50% @ 200 PSI Max. Working Pressure: 200 PSI Amp Draw: 19 Amps Min. Ambient Temp: -40° F Max. Ambient Temp: 158° F Dimensions: 11.50 L x 4.30 W x 6.50 H Net Weight: 11.00 lbs. 480C Tank Fill Rates 2.5 Gallon Tank Fill Rate 0 To 145 PSI 2 Min. 29 Sec. 0 To 200 PSI 5 Min. 02 Sec. 110 To 145 PSI 57 Seconds 165 To 200 PSI 1 Min. 23 Sec. 5 Gallon Tank Fill Rate 0 To 145 PSI 6 Min. 02 Sec. 0 To 200 PSI 10 Min. 08 Sec. 110 To 145 PSI 1 Min. 55 Sec. 165 To 200 PSI 2 Min. 20 Sec. The 480C features include horizontal cooling fins and a trapezoidal head design, a standard 3/8 stainless steel braided leader hose with inline check valve and insulated wiring for simple installation. * Must be used with a 200 PSI or lower pressure, non-adjustable pressure switch when used with an air tank. 480C Performance Data PSI CFM A bar LPM A 0 1.76 10 0 50.0 10 10 1.66 12 1.0 46.0 13 20 1.59 14 2.0 43.0 15 30 1.52 15 3.0 40.5 17 40 1.45 16 4.0 38.5 18 50 1.41 17 5.0 35.5 19 60 1.34 18 6.0 33.0 19 70 1.27 18 7.0 31.5 19 80 1.20 19 8.0 29.5 20 90 1.16 19 9.0 27.0 20 100 1.13 19 10.0 25.0 19 110 1.06 20 11.0 23.0 19 120 1.02 20 12.0 20.5 19 130 0.95 20 13.0 18.0 18 140 0.92 19 14.0 15.5 18 150 0.85 19 15.0 14.0 17 160 0.81 19 16.0 12.0 16 170 0.74 19 17.0 11.0 15 180 0.70 19 190 0.63 18 200 0.56 18 *Supply Voltage: 13.8 Volts
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
I heard the 480s were A LOT quieter than the 380
100% gearhead
Realistically' your probably looking at around 2000-2500+/- to farm out the work.
Also, I don't know what kind of luck I'm gonna have here, but ditch those Viairs. I used to run two 380's. I didn't snap the rod on them, but one of the rods didd fall off the crank and killed that one. I now run one Air Zenith with a five gallon tank and LOVE it! Once you try a Zenith, everything else sucks except mabe an Oasis. |
100% gearhead
100% gearhead
100% gearhead
#13 |
100% gearhead
#14 |
100% gearhead
#15 |
WTF???
what happened, 5 copied posts???
#17 |
I have heard multiple times that the Air Zenith are not having too good of luck.... They have had so many problems with them I refuse to buy one.
#18 |
Resistance is Futile
........in the suspension section I posted a question about air compressors and 2 people said the air-zeniths failed after awhile. Thats 3 total that have the same story. FYI
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#19 |
100% gearhead
Wow! Guess my p.o.s. computer got a bit carried away there! So far I have run the crap out of my Zenith. Not one single bit of trouble. I use so much air, that the thing hardly ever shuts off! It never even gets warm. Besides, now they have the OB1x, which has an improved head and integrated cooling fan.
