03-02-2008, 11:14 PM | #1 |
That POS
Well I took the truck for a drive for the first time in 6 months when I bought it. The engine is running pretty good now but now the tranny dont want to shift. If did it the last time I drove it, I hope hoping for better news then what I think it may be
03-02-2008, 11:19 PM | #2 |
Re: That POS
If you can shift it manually, then first thing to check is the line to the vacuum modulator.
03-02-2008, 11:20 PM | #3 |
Re: That POS
nope couldnt shift in mannually stuck in first.
03-03-2008, 01:36 AM | #4 |
Re: That POS
did you check fluid level once it warmed up?
03-03-2008, 08:55 AM | #5 |
its all about the +6 inches
Re: That POS
when trying to shift manually... you need to rev it a bit higher than where you think it *should* shift... then pop the shifter in 2nd.
03-03-2008, 10:46 AM | #6 | |
Re: That POS
Or just start by checking the line to see if it's disconnected at the modulator...I finally had to put a clamp on mine :/ |
03-03-2008, 09:47 PM | #7 |
Re: That POS
the burb is sittin on the curb for now... too much salt on the streets.
However, my evil plans are coming together and it should be sweet as hell here soon! |
03-04-2008, 06:43 PM | #8 |
Re: That POS
I added some more fluid it was little low tried the manual shift even up high then I thought it should and still nothing...looks like a trip to the tranny shop when I get back
03-05-2008, 06:01 AM | #9 |
Re: That POS
Another thing to look at... if it is a TH350, is the kickdown cable stuck in the fully pulled out position?
