Old 03-03-2008, 03:46 AM   #1
C10 the GEM
Smok'em Roast'em Shift'em
C10 the GEM's Avatar
Deciding on how LOW to go
I just got an 81 chevy stepside shortbed c-10 that i would like to drop. I would like to either go 3 inch front and 4 inch back or 3 inch front and 5 inch back. With the 5 inch flip kit, is a c-notch necessary? Does anyone have pics of either one of these drops. If so state the drop and the parts you used to drop it!
C10 the GEM is offline   Reply With Quote
Old 03-03-2008, 03:57 AM   #2
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: Deciding on how LOW to go
The flip kit is the easiest way to get it real low, and even then you could lower it more by adding a block. With just the flip kit, a c notch is not mandatory, but wouldn't be a bad idea. When my truck had a static drop it had a axle flip without a c notch and I never had a problem.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 03-03-2008, 04:03 AM   #3
C10 the GEM
Which flip kit would you preffer with 5 inch out back but with no c-notch?
Old 03-03-2008, 09:46 PM   #4
smashingchuck
you can do it yourself by welding new perches on the other side of the axle - definitely the cheapest and easiest way if you know how to weld.
Other than that, I'm not really sure who makes the flip kits these days, but I'd go with DJM if they make one.
78 Build Thread
4Runner Build
Old 03-03-2008, 11:48 PM   #5
C10 the GEM
I know how to weld but i want to do is the right way so in the future i dont have to worry about anything. Ya digg
