03-03-2008, 05:09 AM | #1 |
what fan setup
hey guys what electric fans will fit this. its a big block long waterpump 4 core rad i need something skinny.. thanks
nickle and dime Last edited by royo; 12-15-2008 at 03:26 AM. |
03-03-2008, 07:16 AM | #2 |
ran out of money
Re: what fan setup
i have the same setup and have been searching it. looks like a dual fan set-up will be the only thing working or a single with the motor off-set... classic heartbeat has a dual fan set-up i was thinking about or making something like theres of my own. sorry no pics for you but i hope that helps
Modify everything, leave nothing alone!~ |
03-03-2008, 08:04 AM | #3 |
Re: what fan setup
thanks for posting!!!! that fan setup looks to be the best . but i wonder how thick it is. it looks to be high rent though.
nickle and dime |
03-03-2008, 09:26 AM | #4 |
Re: what fan setup
if you don't have an AC, you might be able to mount the fan in front of the radiator and wire it to push the air instead of pull.
1950 Chevy 3100 Ramp Bed 1-ton http://67-72chevytrucks.com/vboard/s...d.php?t=749386 1965 Chevy Step Side 1971 Chevy Short Wide Bed http://67-72chevytrucks.com/vboard/s...d.php?t=277191 1971 Chevy Chevelle 1972 Chevrolet C-30 1 ton 2002 Winnebego Class A MH Ford E-550 Chassis V-10 2005 Dodge Ram 2500 5.9 Cummins 2008 GMC Denali 2020 Jeep Wrangler Unlimited Rubicon |
03-03-2008, 11:08 AM | #5 |
Questionable
Re: what fan setup
This is what I'm running. Maybe it will work for you? No idea. http://67-72chevytrucks.com/vboard/s...d.php?t=216128
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
03-03-2008, 11:09 AM | #6 |
Questionable
Re: what fan setup
PS - I dunno if that shroud is made to fit on a 4-core. My radiator is a 3-core.
03-03-2008, 06:39 PM | #7 |
Re: what fan setup
thanks guys
nickle and dime |
06-16-2008, 03:13 PM | #8 |
Re: what fan setup
Heres what i had to do
nickle and dime |
06-16-2008, 05:23 PM | #9 |
Re: what fan setup
Man im digging that setup in the last picture....very clean.....props for how well its laid out
"Dixie Destroyer" 71 C10 LWB Fleet Future Blown Prostreet Monster |
06-16-2008, 07:22 PM | #10 |
Re: what fan setup
I am just about done with the A/C install in my truck. I just ordered the fan setup that Brothers has, Item: FS072DF, Price: $329.99
Detailed Description Custom mounts to factory fan shroud locations. Fan shroud housing incorporates high-speed ram air bypass. High temperature resistant plastic with patented skewed fan blade technology. High efficiency and fully adjustable thermostatic sensor offers increased fuel economy & horsepower. Requires a 70 amp + alternator. You might not have had enough room for this set-up. I just ordered the fan and it should be here in a couple of days. Here's the link if anyone's interested http://www.brotherstrucks.com/prodin...number=FS072DF
06-16-2008, 07:36 PM | #11 |
sharp as a marble
Re: what fan setup
I had a dual 11" spal set up in my 67 Chevelle, and it was running a decent temp ( a little over 1/2 on the gauge ) unless it was over 95 degrees. The fans fit nicely between the water pump, and was not a hassel to get out if need be. I was running a dual relay, and if I had it to do over I would try one of the SPAL fan controllers. I hear they are great, and simple to hook up. 3600 CFM If I remember
06-16-2008, 10:10 PM | #12 |
Questionable
Re: what fan setup
Hope you don't hit any major bumps with that setup - a lot of the mainstream ties that go through teh radiator fins like that will rip clear through.
