![]() Join Date: Feb 2007
20s And 22s
Whos Running 20s-22s And What Size Tires With A 5-6 Drop Lets See Em
Re: 20s And 22s
Tt
Re: 20s And 22s
Here are my 22s dont know the size and its raining out so i will post size later.
"Your trucks fast! You must have been going 120 when I passed you." "Owning A 10 Sec Import Is Like Coming Out Of The Closet, In The End Ur Still Gay" If for some reason i loose to a import...At least i can go home knowing the vehicle i drive drops girls panties... |
Re: 20s And 22s
Thanks That Looks Sweet Is It A 5 - 6 Drop
Re: 20s And 22s
Tt
Re: 20s And 22s
I have the same wheels in 20/22's. My trucks bagged, but heres a picture of it at ride height so maybe it'll give you an idea of how they'll look. The tires are 255/35/zr20's and 265/35/zr22's. Hope this helps.
Re: 20s And 22s
wrdthird, what mods did you have to do to your truck to get it to sit that low when the bags are down?
Travis
travis_moffatt@hotmail.com ![]() 1969 Chevrolet C-10 LWB, 350c.i., TH350, In Pieces. 1991 GMC Sonoma, IROCS s10 grill 1963 Ford Galaxie 351/C4 |
TILT COLUMN GURU
![]() Join Date: Dec 2006
Re: 20s And 22s
Definately not a truck but I have to share these pics of my buddy Art's 61 Impala with 20 & 22 Intros
knuckle buster..
![]() Join Date: Oct 2007
Re: 20s And 22s
that impala is SWEEEEEEET!!!!!!!
_______________________________________________________________________________ Eric THIS SITE ROCKS!!! ![]() Check out my suburban on 20's with fresh paint! Click here to support the site Check out the Member Photo Gallery here StreetCruizin FAQ thread Site vendors list (scroll down to vendors in red) ![]() ![]() |
Re: 20s And 22s
20's on my yellow truck
Re: 20s And 22s
The front has 2.5 drop spindles with the bags bolted to modified lower control arms. Its pretty much just your standard front setup. The back is 4 linked with a panhard bar and a big notch through the bed. The back of the cab had to be notched a little to clear the drive shaft and the exhaust is ran through the cross member. The bed floor was raised about 5 inchs so the fuel cell could stay under the truck but be high enough not to drag.
Re: 20s And 22s
that impala,is THA SHHHHHHHH!
www.gkautospa.com Like A Rock! http://67-72chevytrucks.com/vboard/s...d.php?t=397153 |
#13 |
PITbut
Re: 20s And 22s
#14 |
Re: 20s And 22s
here some on 22/20
#15 |
Tot Roddin'
Re: 20s And 22s
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#16 |
Re: 20s And 22s
What wheels are those?? They look GOOD!!!
I know what your thinking.......I have ESPN. ![]() Sometimes it's easier to do things the hard way. ![]() Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! ![]() ![]() |
#17 |
its just $$$$$
Re: 20s And 22s
255/35 front, 285/30 rear
#18 |
Re: 20s And 22s
