I want to dump the pertronix kit and install a regular HEI dizzy but it seems like it wont fit my truck. It looks like it will hit the firewall the engine sits back on my truck. Is this normal? have a 305 in it . pics would be great.
68 c-10 1/2 ton swb fleetside, 79 GMC Sierra Grande 1/2 ton swb fleetside, 99 Dodge Durango 4x4(wifes ride ![]() ![]() 54 caddy 62 series 4 door(younger sons ride, aka 54caddy ![]() 70 caddy 2 door, 89 chevy silverado stepside(older sons rides ![]() |
Re: HEI coil in cap dizzys
The HEI distributor fits nicely in the C-10 model trucks but in the K-10 trucks it is a very tight fit. The distributor wires will hit the firewall in the K-10's but you can still use them.
Here is a pic of an HEI in my son's 72 Burb 4x4. As seen in the pic it is a tight fit! Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
I totally agree with Jim it is tight but they work none the less,I am running 1 in my 69 that is slid back in the 6cyl. mount location.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
#4 | |
Sierra Grande Club
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
its all about the +6 inches
your 305 is in the 6 clyinder location... or 4X4 location... either way to word it, it's the same holes.
It'll fit back there, but it's tight. Go for it, best thing you can do IMO. |
I have one on my 402BB no clearence issues.
70 GMC LWB Fleetside, 402BB, TH400 90K original only cost $50. |
#7 | |
![]() Quote:
#8 | |
![]() Quote:
![]() Join Date: Aug 2005
I think MSD's got a low profile model that might make it easier. Probably not cheap though...
#10 | |
![]() Join Date: Dec 2006
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
The main advantage to the GM unit IMO, is any parts store will have the parts on hand. No one will have the aftermarket stuff.
just wondering, do these trucks run a ballast resistor to go to the coil or is this just for the earlier trucks?? If so, pics would be nice to show how to connect with pertronix kit if I decide to keep this in.
#13 |
the resistor is built into the wire on these trucks.
#14 | |
![]() Quote:
#15 |
love this web site, all info is always right on the money!!!
#16 |
Chevy One
The HEI is the way to go on these trucks. I have been buying complete units off the net for $55-60 shipped to my door. These are overseas units (china) have one running in it second year now with no problems. Just my 2 cents!!!
Chevy One ![]() 67 1/2 Two-on-the-Floor 67 Nova 2Dr Sedan 03 Monte Carlo I'M NOT OLD, JUST A CLASSIC!!! |
#17 | |
![]() Quote:
#18 | |
Sierra Grande Club
Most are getting them from Skip White http://stores.ebay.com/whiteperformance1 s/t
#19 | |
Also, I am still unclear: yes or no, The HEI dizzy can be physically installed in a 4x4 k5 without engine removal? Can I get it in there by myself from the top, or do I have to slide the engine fwd to do it? bone stock, no body lift. Thanks!
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett '72 Blazer Restoration Blog: http://sportchicken.blogspot.com/ Last edited by cstanley; 03-08-2008 at 03:32 AM. |
#20 | |
![]() Join Date: Apr 2000
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
#21 |
I have a skip white HEI on the burb... only 5,000 miles or so... maybe more.. but it's been flawless.
#22 |
Fabricate till you "puke"
Call me cheap.....I have an old cast iron dist (mid 60's 283) in my 383. With a recurve/adjustable vac advance, Pertronix Ignitor, & plugged to an ACCEL super coil......I have seen that motor run 7200, & not skip a beat
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#23 | |
Sierra Grande Club
Thats good to hear, thats what I have to use in mine! ![]() If there is a failure will other HEI parts fit? just wondering, I'm thinking of getting a spare module to keep in the glove box. s/t
#24 |
it looked like a GM HEI to me, but I didn't try fitting GM parts on it.
Honestly, I think the whole module thing is a bit blown outta proportion. Sure, it wouldn't hurt to throw one in the glove box... but I've never had one go bad myself, and this burb is the first new HEI I've ever had... everything else always got junk yard units. |
#25 | |
