can someone run my V.I.N ?
i just bought this 68 and it has a v-8 but being the noob that i am, i dont know what size motor it has. here is the vin : CS148S114325
i appreciate all info. |
its all about the +6 inches
Re: can someone run my V.I.N ?
The VIN won't tell you what engine it has. ONly the build sheet or SPID in the glove box can tell you that info. And since your truck originally had an inline, you could have ANYTHING in there.
However, your VIN breaks down as; CS148S114325 C- 2wheel drive S inline 6 (250 or 292) 1- 1/2 ton 4- cab with bed (step OR fleet) 8- 1968 S-0 built in St louis 114325 would be the 14325th one built on that assembly line at that plant for that year. http://67-72chevytrucks.com/Chevyear.html has the VIN info. |
if you go to main board the vin decoder is in the menu on the left side of the screen welcome aboard
thanks for the help. im a little discouraged now. i thought i had an original v-8 truck. so i guess my truck has already been molested?
![]() Join Date: Feb 2004
Welcome to the board, can we get pics, for us picture hounds
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
it's the 68 that i picked up a couple days a go. you posted on my thread.
is there an engine number decoder? this number was on the block in front of the passenger side head: T0806DE
anyone? tks |
Hi, this the list of all DE suffix engine, with the casting number at the rear of engine you have a better idea if it's a 283 or 307 and what year range.
DE 58 283 Impala 185 Base Power glide 2-Brl Air Suspension DE 59 283 Impala 185 Base Power glide 2-Brl Air Suspension DE 64 283 Nova 195 Base Power glide 2-Brl Hyd Cam DE 65 283 Chevelle 195 Base Power glide 2-Brl Hyd Cam DE 66 283 Chevelle 195 Base Power glide 2-Brl Hyd Cam DE 67 283 Chevelle 195 Base Power glide 2-Brl Hyd Cam DE 68 307 Nova 200 L-14 Power glide 2-Brl Hyd Cam DE 68 307 Chevelle 200 L-14 Power glide 2-Brl Hyd Cam DE 69 307 Nova 200 L-14 4-spd 2-Brl Hyd Cam DE 69 307 Chevelle 200 L-14 4-spd 2-Brl Hyd Cam DE 69 307 Camaro 200 L-14 4-spd 2-Brl Hyd Cam
'71 Custom/10 Deluxe LWB '71 Custom/30 Deluxe Dually |
