Almost Satisfied
![]() Join Date: Mar 2002
I have a couple of crossmembers that I am replacing tonight and will need nuts and bolts to replace the old rivet. What size diameter are those rivet holes and what strength bolt is recommended?
------------------ 2001 GMC 2500HD Crew Cab Duramax, Allison, 4WD, Love it 1971 Chevrolet 1/2 ton 2WD Short/Step Side. In process of frame off restoration
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
the rivet holes are probably 3/8. I have replaced anything that was out of the longhorn with 7/16 grade 8 hardware& pinch lock nuts.......69
http://community.webshots.com/user/hotrodhorn |
Almost Satisfied
Sorry 69 to be dense. Should I go with the 3/8 or the 7/16? I live a ways from the hardware store and don't want to make a second trip if possible. Any help would be greatly appreciated.
My goof,I should have stated that I drilled the hole oversized to fit the 7/16 bolts. Im guessin trans crossmember,& farther back...69
I replaced over 60 rivets on my 4x4 frame. I ground a flat spot on the rivet head. Then center punched them. Drilled them with a 1/8 drill about a 1/4 or so deep. Then drilled them with a 3/8 drill the same depth. I didnt want to oval out the hole. Then i took a chizle ond knocked the head off and punched the rivet out..After that i drilled all the holes out at 7/16 because a 7/16-20 bolt measures .429 to .431 and i wanted them to fit tight like a rivet. Then i sand blasted everything and painted it. When i assembled everything i put a flat washer on both sides and put red locktight in the bolt and torqued em down. I can't remember the torque speck.. The bolts were 7/16-20x1" long grade 8.....
Randy ------------------ 72 k/10 short wideside 72 k/5 Blazer 72 custom/10 8' bed 69 c/10 8' bed 71 k/5......rusty!! IT WENT TO THE SCRAP YARD 72 custom/10 short stepside 70 C-30 Longhorn, its Longhornmail's now. 70 K-5 Blazer chester county pennsylvania
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
For critical frame bolts (like suspension and crossmembers) I like to use lugstuds PRESSED into a reamed-to-fit hole and cinched down with a lubricated nylock nut. Looks just like a rivet on the outside, and splined and pressed in for immobility. I have been known to use old studs from whatever old suspension I have layin' around, but new is good, too. Use a generic GM stud from a malibu, for instance.
------------------ Just as if I knew what I was doin'
Just as if I knew what I was doin' |
Almost Satisfied
Thanks for all your help. I got some 3/8 grade 8 3/4" Bolts and they fit the holes perfect and were just the right length. Replacing the first crossmember (in front of the engine) was a job! But, I won in the end.
My truck was a manual to begin with years ago and after I got the cab off the frame I found the new auto trans crossmember only had two bolts holding it in the frame!!! That has been corrected!! ------------------ 2001 GMC 2500HD Crew Cab Duramax, Allison, 4WD, Love it 1971 Chevrolet 1/2 ton 2WD Short/Step Side. In process of frame off restoration
Lug bolts sounds like a good ideal. I'm going to cheak that out myself. If using bolts be sure to use grade 8.
70 short,step on a 72 frame. |
grade 8 has a better clamping strength but a lower shear strength, grade 5 is the recommended bolt to use for frames that flex.
------------------ www.mothertruckers.net
Rest in Peace Ed. Thanks for all the good times. |
