Pictures of clutch rod and zbar installed
Anybody have detailed pictures of installed clucth rod and zbar on V8 engine. I like to make this conversion on my truck. Thank's
'71 Custom/10 Deluxe LWB '71 Custom/30 Deluxe Dually |
This might help...
-Dave
2003 Silverado K1500 Z71 - Arrival Blue 1973 K5 Cheyenne Blazer 350/TH350/NP203 Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift. RETIRED: 1980 Scottsdale 4x4 Founding Member: "TILT WHEEL BELLY." Club |
Re: Pictures of clutch rod and zbar installed
Thank's Dave I found some info in your picture but I like to have pictures installed on the truck to see where each part go on the truck.
Back in the sticks
Here you go...
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
Thank's red71, do you have the pictureof the other end of zbar where the pivot ball are fixed on the frame rail bracket.
Back in the sticks
This is the closest one I have on my computer right now...
Thank's red71 for your fast answer.
I moved mine back on the frame about an inch or so. You can see the original hole in front of the bracket:
Zactly what iIhad to do to clear the Hedmans.
69 K-20 cloned to a 67 with front clip and some other stuff. 383 .040 over Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears: ![]() |
