Old 03-04-2008, 10:24 AM   #1
Chevyman680063
Chevyman680063's Avatar
Cam Question
I would like to know what size cam you guys think would be a good size to go with in a daily driver that has a GM Goodwrench 350 crate with 250 hp. and 350 ft. lbs. of torque in it. I was looking for a cam that would give me that lopey idle but didn't want to go with something too extreme since it will be driven daily. I emailed Summit Racing about it and they told me that this cam would be good for what I was wanting. What are your guys thoughts on this cam and will it give me enough of that lopey idle sound?
http://store.summitracing.com/partde...w=1&N=700+150+
Chevyman680063 is offline   Reply With Quote
Old 03-04-2008, 10:43 AM   #2
Billla
Billla's Avatar
Re: Cam Question
What you describe is exactly what the Thumpr cams from CompCams are about. Wasting power, gas and driveability for noise, but if that's your bag then these are your cams. The 93438649 heads on your 250 HP crate are lift-limited to .475...so you'd be right there on the hydraulic flat-tappet version at .479/.465 - measure carefully
http://www.compcams.com/Thumpr/default.asp
Billla is offline   Reply With Quote
Old 03-05-2008, 01:22 AM   #3
MikeN
MikeN's Avatar
Re: Cam Question
Check out the Lunati VooDoo 256H
MikeN is offline   Reply With Quote
Old 03-05-2008, 02:41 AM   #4
Billla
Billla's Avatar
Re: Cam Question
? Lunati doesn't number their cams like that - looks like a CompCams number...?
Old 03-05-2008, 04:27 AM   #5
Blackbird66
Re: Cam Question
I am a BBBBBBBBBIIIIIIIIIIIIGGGGGGGGGGGG fan of the old 350hp 327 cam from gm in a street chevy. It makes good power from idle to red line, has a nice idle ( although it may not lope as much as you want ) and is the same cam I believe that is used in the 290 HP gm goodwrench motor
Blackbird66 is offline   Reply With Quote
Old 03-05-2008, 07:54 AM   #6
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Re: Cam Question
I think that cam is to large for a daily driver.
Look for something that works from 1500 and up.
Call Steve @ Lunati he can offer some sound advice.
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 03-08-2008, 01:32 AM   #7
MikeN
MikeN's Avatar
Re: Cam Question
The smallest hydraulic flat tappet VooDoo...think they call it a 256 cam...P/N 60101
Old 03-08-2008, 01:34 AM   #8
MikeN
MikeN's Avatar
Re: Cam Question
The 290HP crate motor has a different cam, the 350hp 350 cam, which is slightly larger than the 327/350 cam. And FWIW, I ran the 327/350 cam in a 350 and was somewhat disappointed. To work it's best, that cam really needs more compression than modern unleaded 93 allows.
Old 03-08-2008, 02:07 AM   #9
Ole Blue 68
Ole Blue 68's Avatar
Re: Cam Question
I'm running the 600101 in my 68 and i'm liking it. Nice sound at idle, decent performance yet still good for daily driving.
Ole Blue 68 is offline   Reply With Quote
Old 03-08-2008, 07:28 AM   #10
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: Cam Question
Is yours a Voodoo series?, if so I think you meant 60101.
I'm going to be using the next one larger in my truck 60102 in my 383. But they
say that the stroker will act milder than a 350 with the same cam.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 03-08-2008, 07:59 PM   #11
Ole Blue 68
Re: Cam Question
Yeah, it's the Voodoo #60101. Sorry for the typo.
Old 03-08-2008, 08:10 PM   #12
68Stepbed
68Stepbed's Avatar
Re: Cam Question
I have the same engine with a COMPCAMS XE262. I LOVE it. It was the biggest cam they recommended with stock springs. The idle is just enough to know there's something there, but isn't too radical to drive on the street. It pulls real hard from about 2000-5000 rpm. I currently have a TH350 trans with a 3.73 gear. It likes the low gears, but I'm going to a 3.42 gear soon.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 03-08-2008, 10:08 PM   #13
bad421
bad421's Avatar
Re: Cam Question
check out the comp cams extreme line very nice if you get the complete kit, put the .477/.480 kit in a mild 350 sounded very good and made good power in a 87 k10 with 35" tires and 3.73s
ASE MASTER TECH
  • 1968 K10 LT1 350,SM420,T-221 lwb fleetSold
  • 2007 Ford Ranger DD
  • 2000 Ford F250SD V10 4x4
  • 1968 Pontiac Firebird 468/TH400 current project
  • 1991 Dodge W350 SRW CUMMINS POWERED
Whole lotta fuel and a whole lotta Smoke
bad421 is offline   Reply With Quote
