Old 03-04-2008, 10:41 AM   #1
skokie
skokie's Avatar
Truck is not running right.
Ok I changed the oil in my 01 sierra and then pulled up the 68 to change its oil. After it was done I started it and after a minute or so it started running bad. It was going down to 500 rpm and would try to go dead unless I gave it gas. Since I was planning a putting the new qjet with the electric choke on it I left it and came back to it tonight.
I put the new carb on qjet 17066553 and it is running a little better but it will idle at 800 then go down to 650-700 then back up to 800. Its got me stumped on what it could be. Any one seen this before?
Thanks in advance.
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 03-04-2008, 12:16 PM   #2
CCCC
CCCC's Avatar
Re: Truck is not running right.
With the little bit of info available, my first thought would be a vacuum leak - that is, some vac line or connector is open - and the intake is sucking air after the carb mix. With the idle speed fluctuation, sounds like it may be an intermittent leak. Maybe a line or connector was bumped in the oil change operation - posibly at the brake vac booster or ??? Hope this helps.
CCCC
67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison
Moved but still in the family
70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350
Recently sent to new homes
72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp
CCCC is offline   Reply With Quote
Old 03-04-2008, 12:45 PM   #3
72swb_327stroker_?
knuckle buster..
72swb_327stroker_?'s Avatar
yup, sounds like a vacuum leak.
_______________________________________________________________________________
Eric
THIS SITE ROCKS!!!
Check out my suburban on 20's with fresh paint!
Click here to support the site
Check out the Member Photo Gallery here
StreetCruizin
FAQ thread
Site vendors list (scroll down to vendors in red)
join the the smilies fight club
72swb_327stroker_? is offline   Reply With Quote
Old 03-04-2008, 12:47 PM   #4
berencam
berencam's Avatar
i agree with the vacuum leak also but its kinda odd it happened right after a oil change..... did you mabee nick a vacuum line or something while you where in there?
69 chevy c10 350 3 speed manual wood bed build thread here r.i.p.
70 c10 auto 350 build here
berencam is offline   Reply With Quote
Old 03-04-2008, 10:14 PM   #5
skokie
skokie's Avatar
I checked the vac lines behind the intake. One goes to the 400 turbo and the other is to the vac guage. I will check the other end of the line going to the tranny and the brake booster. Also when I changed the carb I put on a new gasket on the intake.
68 build thread
Old 03-05-2008, 01:45 AM   #6
skokie
skokie's Avatar
One more thing to add to this is could my hei coil be going out?
68 build thread
Old 03-05-2008, 02:06 AM   #7
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Vacuum leak, not your coil going out. Could be a vac line cracked, or worn throttle shafts, or bad power brake booster, or vac line going to the power brake booster.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 03-06-2008, 09:47 AM   #8
skokie
skokie's Avatar
Ok here is the latest. I checked/changed where needed my vac lines so that is good. The only thing that I did was go from a wix 51060 oil filter to a 51061. I called the parts store and was told the only difference between the two was that the 51060 had the drain back valve and the 51061 does not. Just for the heck of it I am going to go down there tomorrow and pick up a 51060 filter. I dont see why it would work but it why now.
68 build thread
Old 03-07-2008, 07:30 AM   #9
skokie
skokie's Avatar
Ok I have checked every vac line I can find and put in the same part number that I took out same thing. Dont know what else to check so I will be taking it into the shop tomorrow. Will post back when they tell me what it is.
68 build thread
Old 03-07-2008, 07:38 AM   #10
AlienYouth
AlienYouth's Avatar
I'm having the same problem, im not too worried cause i'm puttin in a new motor soon, but it would be nice to have fixed for the next few weeks
Picturesss
71 C10 383/TH400
13.65 @ 99... 2.06 60' spinnin :/
AlienYouth is offline   Reply With Quote
Old 03-07-2008, 07:38 AM   #11
68C15
blood type; Retumbo
68C15's Avatar
it sounds to me like you have had 2 seperate problems. HAD 2, now just one. the first sounds like a stuck float, plugged air bleed in the carb, etc. doesnt matter much now that you changed the carb.
the current problem with the hunting idle sounds like it may be a vacuum advance on the verge of advance. pull the hose and see how it acts.
I remember recently someone here had a link to a retired GM engineer who did a write up on vacuum advance tuning. any leads people?
68C15 is offline   Reply With Quote
Old 03-07-2008, 07:40 AM   #12
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Use an unlit propane torch to find your vacuum leak. I know sometimes you want to light the torch! But you'll regret it later.
use the propane to check the shaft seals on the carb too.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 03-07-2008, 09:28 PM   #13
joedoozer
is Certifiable
joedoozer's Avatar
Yeah and that Power Brake Booster idea is a good one. You did drive it, and hit the brakes. Possible it went bad.
joedoozer is offline   Reply With Quote
Old 03-09-2008, 04:08 AM   #14
skokie
skokie's Avatar
Had the truck towed to the shop. As I was leaving they started it up and it was blowing blue smoke out of both pipes.
68 build thread
Old 03-09-2008, 04:17 AM   #15
haysonj
haysonj's Avatar
Sounds like you did something to the carb when you changed the gasket. maybe stuck the floats
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 03-10-2008, 01:14 AM   #16
skokie
skokie's Avatar
Ok I got a call from the shop and it was a few different things.
1. carb out of adjustment (guilty I tried) LOL
2. dizzy cap loose
3. and the biggest one was that most of my valves were to tight.
The mechanic said that my valves were over tightened. It was probably like that since I got the crate motor. I have not touched the valves. In short he said its running great. He adjusted the valves, adjusted the carb, and set the timing.
He also said that he had a 68 LWB a few years ago and sold it. My truck reminded him of what a mistake he made Said that he loved how easy it was to work on these. On my way to pick it up. Thanks for all of the suggestions for the help. It is greatly appreciated.
68 build thread
Old 03-10-2008, 01:20 AM   #17
Sport/Truck
Sierra Grande Club
Old 03-10-2008, 02:28 AM   #18
skokie
skokie's Avatar
Originally Posted by Sport/Truck View Post
hahhahahahah
68 build thread
Old 03-11-2008, 03:22 AM   #19
skokie
skokie's Avatar
I drove the truck today. Big difference even sqweaked the tires when going to second
68 build thread
Old 03-11-2008, 07:41 AM   #20
Boog
laying low
Boog's Avatar
Well now. That's sounding better. You've gotter on the road now.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 03-11-2008, 08:49 AM   #21
skokie
skokie's Avatar
Yep. It was like it was sick and when it chirped 2nd it was saying im all better now
68 build thread
