Old 03-04-2008, 06:30 PM   #1
'70_402
'70_402's Avatar
can they fit?
i am putting a new 468 in my truck... can i run the edelbrock elite tall valve covers and not hit the brake booster on the driver side? got roller rockers and need the tall ones.... big block, 1970, power brakes, will they clear? anyone have pics?
thanks
'70_402 is offline   Reply With Quote
Old 03-04-2008, 10:48 PM   #2
'70_402
'70_402's Avatar
Re: can they fit?
ttt.... the motor isn't in the truck yet so i don't know.
Old 03-05-2008, 05:35 AM   #3
'70_402
'70_402's Avatar
Re: can they fit?
anyone?
Old 03-05-2008, 06:45 AM   #4
71Rat
ran out of money
71Rat's Avatar
Re: can they fit?
how bigs your booster? i have a bbc with mildly tall covers and its close but they fit. if memory serves me correct my booster is 11 3/4. if you really want to use those valve covers switch to a dual 8 inch booster
Modify everything, leave nothing alone!~
71Rat is offline   Reply With Quote
Old 03-05-2008, 07:03 AM   #5
'70_402
'70_402's Avatar
Re: can they fit?
do you have roller rockers?
Old 03-05-2008, 07:27 AM   #6
71big block
1971 GMC 3/4 ton, 572 CID
71big block's Avatar
Re: can they fit?
I've been told that the Elites won't fit with the stock booster but I've never tried them. I run the tall Edelbrock crome with my roller rockers
71 GMC 3/4 572 CID,
1988 GMC 1/2
2006 Saturn Vue
"We always have parts left over on a job this size"
71big block is offline   Reply With Quote
Old 03-05-2008, 07:36 AM   #7
71Rat
ran out of money
71Rat's Avatar
Re: can they fit?
mines a roller rocker motor with cheap chrome steals they are taller then a stock valve cover but not as tall as some talls i have seen
Old 03-05-2008, 06:04 PM   #8
'70_402
'70_402's Avatar
Re: can they fit?
i have never had good luck with the stamped steel ones... i know people run them all the time. i guess it's just something i do.. plus i really want to use the cast alum. ones.. or the elites of course. here is a couple of pics of the motor so far... those elites are really tall....
Old 03-06-2008, 07:20 AM   #9
RustyParts
RustyParts's Avatar
Re: can they fit?
Here's a pic of a 454 in my Jimmy. The valve covers I have are maybe a 1/2" taller than the stock ones, pretty close. The tall ones I believe will fit but you may have to loosen the booster to get them off.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires
The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers!
RustyParts is offline   Reply With Quote
Old 03-06-2008, 07:56 AM   #10
corn
Re: can they fit?
Do you have the stock bb towers? If so I can measure how much room I have between the head with the cover off, to the booster on my 69 if you want. I have the covers off right now anyway so its no big deal...
corn is offline   Reply With Quote
Old 03-06-2008, 08:51 AM   #11
'70_402
'70_402's Avatar
Re: can they fit?
yes i do have stock towers..
Old 03-06-2008, 03:50 PM   #12
Re: can they fit?
If you have the`70 booster,isn`t it a smaller diameter than 71/72?
Old 03-06-2008, 08:50 PM   #13
Luvlegs
Luvlegs's Avatar
Re: can they fit?
Will the 72 only motor mounts lower it enough to clear even more?
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
