Old 03-05-2008, 05:59 PM   #1
HavinSomeFun
Still Just Havin Some Fun!
HavinSomeFun's Avatar
Pulling Disc Brakes from a 72 to install on 67
What parts do I need to take besides the spindels and rotors?
a green one with some stuff done to it....
HavinSomeFun is offline   Reply With Quote
Old 03-05-2008, 06:15 PM   #2
Jim_PA
Re: Pulling Disc Brakes from a 72 to install on 67
I would take the whole front crossmember. The drag link and everything are different, but the 67 link can be made to work with the right tie rod ends if that's not an option.
Jim_PA is offline   Reply With Quote
Old 03-05-2008, 06:19 PM   #3
Jim_PA
Have you considered doing a 73+ front crossmember swap? If I had it to do over again, I might have just gone up to that setup. The ball joints tie rod ends, etc are much less expensive.
Old 03-05-2008, 06:42 PM   #4
lilred67
lilred67's Avatar
you will need all the brake lines ( metal & rubber ) from the spindles to the master cylinder. the lines route differently on the disc brake trucks. get all the steering linkage, this will make the swap easier. you will have to change your lower ball joints( buy new ). when i done mine i swapped spindles & upper a-frames,steering linkage,all brake lines with brackets from a '72
lilred67 is offline   Reply With Quote
Old 03-05-2008, 11:03 PM   #5
HavinSomeFun
That helps a bunch!
Old 03-05-2008, 11:59 PM   #6
jugernot
Life, Be In It.....
jugernot's Avatar
I agree.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 03-06-2008, 12:02 AM   #7
hilljob26
hilljob26's Avatar
i second the whole crossmember thing,you will save a ton in replacement parts
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 03-06-2008, 04:40 AM   #8
shortbed70
shortbed70's Avatar
I am using 72 disc for my 65 so can I use my lowers if I buy new ball joint and if so what do I buy?
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
