Location of solenoids on door?
When the weather breaks, I need to install the door solenoids without interferance of the windows operation. Anyone who has done the solenoid install inside our truck doors that have pics/ or install notes? Even with the cable extensions I can't see how to get a straight pull for the solenoids. Any help out there?
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
'69 Step
Re: Location of solenoids on door?
In relation to the VIN plate, mine are about 3 inches down in the corners of the doors. The pull mechanism is about 6 inches long and is fairly straight. No problem with window operation. If you haven't bought them yet, I would recommend get 50 lb or above.
It's my truck, and Yes, I CUT the dash, so what?? |
I already have them. You drilled thru the door to mount them then?
Thanks for the reply.
