Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 03-05-2008, 11:34 PM   #1
fun in dirt
fun in dirt's Avatar
amp tuning
Took off work yesterday & finished installing my new system in the Blazer. I'll post some pics tomorrow! In short, I've got a Sony CDX-M30 marine receiver,two Polk 4" 2ways mounted in console, and two Polk 6x9 3ways in the rear side panels all hook to a Kenwood amp. It all works good but the 6x9 speakers sound bad/very muffled; the 4" are much crisper. Anyway, all to say I don't have a clue how to tune on the amp. What all do I need to know to determine how it should be set?
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 03-06-2008, 04:36 AM   #2
Classic69
Love That '69
Classic69's Avatar
Re: amp tuning
Something along these lines I guess:
Step 1:
Adjust the gain all the way down on your amplifier. Be sure to also turn down the bass boost and any other volume-related settings.
Step 2:
Set the passover to the correct setting, if applicable to your amplifier. Set it to "high pass" for tweeters, "full" for midrange speakers and "low" for subwoofers.
Step 3:
Turn your amplifier and car radio on. Set the radio volume to your normal listening level.
Step 4:
Increase the gain slowly until the speaker reaches the desired level and does not distort. Once you hear distortion, the gain is set too high.
Step 5:
Adjust the bass boost to your desired level if your amplifier has that feature.
Step 6:
Crank up the tunes and enjoy your stereo system!!!!
I AM CANADIAN!!!!!
1969 Chevy C/10 Truck - SBC V8, TH-350, 3.73 Posi, 1000W Rockford Fosgate Stereo System, B&M Megashifter, GT Grant Steering Wheel, Dual Magnaflow Exhaust System, Dynomax Headers, Lowered 1" Front & 3" Rear, Front/Rear Sway Bars, Racing Seats, 6000K HID Headlights
2008 Chevy Colorado LT - 3.7L I5, 4 Speed Automatic, Crew Cab, 4X4, Z71 Off-Road Package, "Ground Effects" Package, K&N Cold Air Intake, Supermod PTB, Magnaflow Exhaust w/ Resonator, 500W Kenwood / Rockford Fosgate Stereo System, Custom LED Lighting, 6000K HID Low's / High's, Blackcat Customs Gauges / Needles, Carbon Fiber Interior Accents, KrFabs 2" Lift Shackles / Torsion Bar Crank with Rancho RS5000 Shocks, Superskids Skid Plates
Classic69 is offline   Reply With Quote
Old 03-06-2008, 07:21 PM   #3
fun in dirt
Re: amp tuning
Thanks!
pics are here on this post : http://67-72chevytrucks.com/vboard/s...=1#post2612324
'85 K30 "Big Nassy"
'06 C1500 WT...DD
Old 03-06-2008, 08:14 PM   #4
Classic69
Love That '69
Classic69's Avatar
Re: amp tuning
Looks like you have a very nice interior in your blazer. You will be getting the most out of your speakers with the amplifier. They will play louder and cleaner, compared to if you had them hooked up to the deck. Have fun!!
Just one question....Where did you get your center console? I like the look of it.
I AM CANADIAN!!!!!
Old 03-06-2008, 09:54 PM   #5
Brad
Out of the carpool lane.
Brad's Avatar
Re: amp tuning
Those consoles come in 80's Blazers, Suburbans, etc. I don't remember the full years.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 03-06-2008, 11:29 PM   #6
fun in dirt
Re: amp tuning
Brad's right; this one was out of a '91 suburban.
'85 K30 "Big Nassy"
'06 C1500 WT...DD
Old 05-08-2008, 12:55 AM   #7
Riveted1
Tasty Cakes!
Riveted1's Avatar
Re: amp tuning
I know this thread is kinda old, but here is the proper way to set gain on an amp: (taken from here)
This is a Tutorial on proper settings of an amplifiers gain structure.
First a little knowledge on the gain and what it does. A common misconception is that the gain is like a volume knob, or another one is that ½ way equals 50% power, and all the way equals 100%. These are not true, the gain is a level matching device, to allow you to match the signal being sent from your cd player, and create the most amount of power, without clipping which is the cause of distortion and excess heat to the voice coil. With most newer cd players being at least 4 volt outputs or more, there isn’t a need to turn the gains up as high as with, a 2 or even 1 volt RCA preouts. We will show you what clipping sounds like, and what it visually looks like at the end of the presentation.
We will first start with the items needed:
A digital multi meter or DMM , they can be purchased at a Radio Shack, automotive parts store, or Walmart in the automotive department, for usually around $15-20 dollars. The multi meter is a basic trouble shooting device that all 12-volt mobile electronics enthusiasts should have.
A screwdriver, or other device for adjusting the settings on the amp.
A cd with test tones, a 50hz 0-db, for setting of the gain on a sub-woofer amp, and a 150 Hz for setting the gains the other speakers in the vehicle, and then a tone for setting your crossovers. This tone is dependent on where you decide you want your amplifier crossed over at. For example. If you want to low pass your sub-woofers at 80hz. You will need an 80hz 0 db tone. If you want to lowpass them at 65hz, then a 65hz 0 db tone is needed.
Next we will be using a basic formula to figure out where the gain needs to be set.
For this you need to know how much power your amplifier is rated at.
We will use a 2 channel nine.2. It is rated at 400 watts by 1 at 4 ohms when bridged.
The formula is sq root of Watts x resistance(ohm load)
400 watts by 4 ohm is 1600 then we find the sq root of 1600 which is equal to 40
We now know that 40 volts is equal to 400 watts.
This 40 volts will be found with the DMM.
Now we will begin.
The first step is to turn your cd player on. Then set any boost settings, or eq setting to 0 or flat, turn bass boost or loudness features off.
If your cd player has crossover settings, and you decide to use those over the amplifiers, I suggest you turn those on now. A sub-woofer low pass setting should be no higher than 120hz, we recommend 80hz or lower, depending on listening preference. The high pass on the rest of the speakers in the vehicle should be around the same point as the low pass. For explanation purposes we will use 80hz today.
If you have more than one amp in the vehicle, I recommend you unhook the amps not being set. This will prevent any damage to the other speakers in the vehicle.
The next step is to go to the amplifier and set the x over setting to full. If using a mono block amp such as a nine, turn the crossover all the way up so it does not affect the signal.
Then proceed to make sure the gain is turned all the way down.
You will then hook the DMM up to the speaker terminals with the speaker wire in them, one in the positive one in the negative. You will keep the speakers connected during the process.
The dmm will need to be turned on, and set to voltage ac, your DMM owners manual should explain to you where voltage AC is at. As for the number settings, you will want to have the decimal place at a hundredth, for example 00.00
Since we are testing the nine.2 bridged for a sub-woofer. I will be using the 50hz tone. If setting the gain for upper frequency drivers the 150hz tone will be used.
Insert the tone cd and then proceed to turn the cd player volume to 75%. If using stock speakers running off the cd player, then turn it up to where they start to distort, and then down a little bit.
Turn the 0 db 50hz tone onto repeat.
With the DMM running, slowly turn the gains up, you will notice the voltage increase, slowly turn the gain up until 40 volts is reached.
With the 40volts being reached the speaker is seeing 400 watts. You can then stop the tone and turn the cd player down.
Now if you are using the amplifiers crossovers, we will be setting these now. Since we have a sub-woofer hooked up, we will turn the crossover to Low pass filter, or LPF. The LPF dial will then be turned all the way up. Since we decided to cross the sub over at 80 Hz, we will throw the 80hz tone into the cd player, we will then turn the volume up a little bit, so the sub is noticeable, no need to be turned up all the way. Put on repeat.
The LPF dial will be slowly turned down until the sub-woofer starts to not play the tone with the intensity it did before, The sub-woofer will not stop completely playing the tone, but it will get quieter. You will then slightly turn the crossover back until the speaker is playing with all intensity again. You are then crossed over around 80hz.
The same goes for a other speakers playing your upper frequency range, only you will want to set the amp to high pass filter or HPF, and use the HPF dial.
Now that your gain and crossover is set properly the chance of damaging your speaker and amps is cut significantly, but you need to remember, a lot of music today is recorded with clipping, so you still need to be careful and watch for signs of driver stress.
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
