Old 03-06-2008, 01:52 AM   #1
JAKES 68GMC
Aluminum slot wheels rule...
Lifting my truck
I want to put a 2" lift in my truck just to raise it up alittle...it feels low compared to the old one. I was planning on putting 2" blocks in the back, but I dont know how to lift the front. Maybe cranking the torsion bars? Any help would be appreciated...because I have no clue how to lift the front. Thanks.
JAKES 68GMC is offline   Reply With Quote
Old 03-06-2008, 05:44 AM   #2
Re: Lifting my truck
Rancho makes a torsion bar lift that`s not too expensive for 1500s.They may just be 2500HD/3500 parts,because they don`t make anything but the assembly-drop lifts for 8-luggers.On my 3500 I tweeked the t-bars for about another 2-3".I can run 285/75x16s.I run 255/85x16s now.
Old 03-06-2008, 06:20 AM   #3
JAKES 68GMC
Tim, exactly how did you tweak the torsion bars? I have no clue when it comes to IFS stuff, I just want my truck to ride alittle higher. Thanks for your help.
Old 03-06-2008, 06:35 AM   #4
At the back end of the torsion bars there`s a huge hex head.You turn then=m upYou can go a ouple few inches and still have adequate travel(camber).If you don`t have a wrench,asee if a shop will do it.It won`t cost much at all and can be done in minutes.
Her`s my other truck,R.I.P.:
Old 03-06-2008, 06:46 AM   #5
JAKES 68GMC
Oh ok, thats what I thought. I've heard of cranking torsion bars up before. So you think this will get me a couple more inches without hurting anything?
Old 03-06-2008, 08:49 AM   #6
Yukon Jack
Post Whore
Yukon Jack's Avatar
I adjusted my torsion bars to gain a bit of lift on my 95 GMC Yukon. Approximately 2 years later I had to replace the upper ball joints and had some wear on a couple steering components (can't remember exactly what was worn at this point). Can't swear this was caused from the torsion bars being adjusted but that is my suspicion.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 03-06-2008, 10:45 AM   #7
Blue_71
Bloo
Blue_71's Avatar
probably idler and pitman yukon, those suckers wear out quick!!
i think, if i remember right, the nut to adjust is an 18mm head
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 03-06-2008, 12:10 PM   #8
Wreckless_71
Wreckless_71's Avatar
My dad has a '05 duramax and cranked up the torsionbars then had it aligned again to adjust for the camber/caster, we've got a buddy with an alignment shop so it wasn't any big deal... it looks a lot better than stock anyways.
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project.
1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver.
Wreckless_71 is offline   Reply With Quote
Old 03-06-2008, 04:02 PM   #9
My GMC has 250,000mi. on it and I did this back in`92.The only thing I`ve ever had done to the front end is the idler arm every 80,000 or so.This is typical of all IFS GMs.My alignment never has been touched,either.The IFS is designed to maintain proper camber within it`s travel range.So,no probs there.
Old 03-06-2008, 09:10 PM   #10
gn4u2c2
Tim !! When are you going to be home ?? I want to stop in and chat a few min if possible. maybe monday ?? thanks 443-398-7326
gn4u2c2 is offline   Reply With Quote
Old 03-07-2008, 01:27 AM   #11
Sounds good #2.I`m home in the eves/nights.There`s a swap meet at Howard County Fairgrounds (I-70 & MD32,actually off of MD144 west of 32) on Saturday.I`m working in Westminster tommorrow & Fri.
Old 03-07-2008, 02:45 AM   #12
JAKES 68GMC
Thanks for the help guys, appreciate it.
