Old 03-06-2008, 02:30 AM   #1
truckn'
truckn''s Avatar
sm 465 tranny
hey guys, probably gonna buy this 4 speed tranny off a local guy. what does it mean to have pto (rear output) don't mean to sound stupid but only dumb question is one not asked. thx
truckn' is offline   Reply With Quote
Old 03-06-2008, 03:30 AM   #2
slug
slug's Avatar
Re: sm 465 tranny
Pto (power Take Off) It Is Used In Trucks To Drive Ceartain Accesories. (hydraulic Pump, Winch, Dump Bed)
slug is offline   Reply With Quote
Old 03-06-2008, 06:48 AM   #3
greg64
greg64's Avatar
Re: sm 465 tranny
....And the SM465 has two PTOs (both sides of the case). I have a 465 in my 77. Great transmission, although the granny low is only rarely useful (*). I usually start in 2nd.
Have a look at this link: http://www.novak-adapt.com/knowledge/sm465.htm for lots of info.
Watch the bellhousing... it's different from the standard GM one in that the indexing ring is larger on the tranny than the standard bell hole. Need a cast iron bellhousing to match.
* When I'm pulling a heavy load, having the granny low is great to get things moving without leaving my clutch as dust on the road.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 03-06-2008, 08:54 AM   #4
truckn'
truckn''s Avatar
Re: sm 465 tranny
thx guys $100 bones is probably a pretty good score then would you say?
Old 03-06-2008, 10:29 AM   #5
greg64
greg64's Avatar
Re: sm 465 tranny
Ya, $100 bucks would be a good deal for a usable unit. I guess because they're heavy (180 lbs) and aren't useful to the pony car crowd, they don't seem to ever command a high price. Novak offers fully rebuilt ones for $1000, which would be a steal for a 5 speed with O/D. Heck a Muncie 4 speed (M20/21/22) would be worth many times more than a 465, but they aren't half as tough.
What rear gears do you have, truckin?
Greg
Old 03-06-2008, 03:43 PM   #6
truckn'
truckn''s Avatar
Re: sm 465 tranny
I'm not sure greg it's a stock rear end, the one thing I need is the low granny gear because I pull my pontoon boat up my very steep and long drive way.
Old 03-06-2008, 07:52 PM   #7
greg64
greg64's Avatar
Re: sm 465 tranny
Oh, well you'll like the 465 then. About the only thing in this class that can beat it for low end is the SM420. Everything more modern for the <1T trucks doesn't have as good a crawl ratio.
Greg
Old 03-07-2008, 06:13 AM   #8
Fred T
Cantankerous Geezer
Fred T's Avatar
Re: sm 465 tranny
I prefer the SM420 over the 465. It's smaller, lighter and shifts faster and easier. But use what you can get, they're both next to indestructable.
I'm also not an expert on the rear pto. If not needed, I would remove it if possible, and sell it. Seems to be a good market for pto's. And you will have one less place for drips.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
