Old 03-06-2008, 06:47 AM   #1
lyrikz
PITbut
lyrikz's Avatar
Grinding welds, what do you use?
Lately i have been using a 4 inch grinder to get the welds down, then a sanding disk on an air wheel to get it smooth.. Only problem i seem to run into is that i hit the surrounding metal quite a bit and im sure its thinning it out. Thinning out already thin metal isnt very good....
I was thinking what if you used a dremel with a little metal bit on it... That work better? IM open for all suggestions on what you guys use...
lyrikz is offline   Reply With Quote
Old 03-06-2008, 06:51 AM   #2
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: Grinding welds, what do you use?
I've seen a lot of people use flap disks attached to either a d.a. sander or 4 inch grinder. They seem to do wonders, please chime in if I am wrong.
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 03-06-2008, 06:52 AM   #3
tcb-1
Nothing to see here.....
tcb-1's Avatar
a dremel may take too long.
I use a flapper wheel once the weld is ground down some. It still is a bit big to get into sharp corners though....
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 03-06-2008, 07:08 AM   #4
I have a 4 and 4 1/2 inch grinder. I use both a grinding disc and flapper discs, mostly the flapper disks when I am doing sheet metal work.
Old 03-06-2008, 07:17 AM   #5
suville
suville's Avatar
You can buy a welding wire I believe its called "easy grind" and if my memory serves me its made by USAB ? Anybody have any more info on the source? I tried a roll of it didnt think it was much different and I had to special order it from the local welding store!
suville is offline   Reply With Quote
Old 03-06-2008, 08:15 AM   #6
powerbench
powerbench's Avatar
4 inch grinder wih flapper disk's and a 90degree die grinder with 3M Roloc sanding disk
powerbench is offline   Reply With Quote
Old 03-06-2008, 08:31 AM   #7
arkracing
Weekend Warrior
I use a 4" grinder with the "butcher" grinding wheels to grind down the bulk of the weld, and then a Flapper.
The 5" air grinders are great @ doing what you described - grind the surrounding metal. They are good for a quick blending of a large area - but that is about it.
What type of metal are welding/grinding - sheet metal or thicker "frame/bracket" thickness stuff?
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 03-06-2008, 09:12 AM   #8
Shane
Shane's Avatar
For sheetmetal work: 4" cutoff wheel first in a straight die grinder ... then an 80 grit flap disc ... then a 120 grit flap (both in cheap HF 4" grinders) ... and last a 3" 180 grit 3M Roloc in a 90 degree die grinder.
Anything thicker than 1/8" is a 4" grinder with a 60 grit grinding stone followed by the flap discs listed above then then Roloc
Shane is offline   Reply With Quote
Old 03-06-2008, 11:59 AM   #9
Dingfodgy
Lemme show you something!!
Dingfodgy's Avatar
Nothin' but flap discs for this homie! First I hit it with a 60 grit, then a 120. Finally, I'll blend it all with a 180 flapper. For the tight places- nothing beats a dynabrade narrow belt sander.....tis da' shiznit!
'67 CST-10 LWB ("Crusty") SOLD
'67 GMC SWB ("Murdock")
2000 K1500 Suburban ("Betty")
'95 BMW 325i ("Joy")
Dingfodgy is offline   Reply With Quote
Old 03-06-2008, 06:41 PM   #10
jaros44sr
jaros44sr's Avatar
Attachment 342076
There's a tool I don't have, any more info where I can get one
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 03-06-2008, 09:58 PM   #11
lyrikz
PITbut
lyrikz's Avatar
Attachment 342076
Anyone have a pic of this flap discs??? You put the flap discs in your grinders?
Old 03-06-2008, 10:25 PM   #12
Jim_PA
Yeah, you put the flap disk in the grinder. It's like sandpaper, but it's in little sections, and they all overlap to form a circle. I don't know how/why they are better than just sandpaper, but I messed with one the other day, and I was impressed with how evenly it sanded the area I was testing.
Jim_PA is offline   Reply With Quote
Old 03-06-2008, 11:36 PM   #13
Dingfodgy
Dingfodgy's Avatar
Here's some distributors in the Philly area that you could check out. Be advised these tools, although pert near bullet-proof, are not cheap. I think I paid ~$425 for my dynafile- there may be cheaper brands out there, but it was an employee purchase dealio- so it just came out of my payroll for a few months. If I had to fork over all the scratch at once.....fogettaboudit!
Philadelphia, PA A. A. Abrasives 215-925-6367 1.03
Trevose, PA Industrial Supplies Co. 800-359-6200 16.69
Boothwyn, PA E & R Industrial Sales, Inc. 610-485-9700 17.15
Trainer, PA E & R Industrial Sales, Inc. 17.15
North Wales, PA Maxwell Products 215-699-2224 18.87
Old 03-06-2008, 11:37 PM   #14
Shane
Shane's Avatar
flap disc ala' google
Old 03-06-2008, 11:41 PM   #15
cstm68
cstm68's Avatar
i use these all the time and i dont need to use any filler. just a coat or two of primer.
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 03-06-2008, 11:47 PM   #16
lyrikz
PITbut
lyrikz's Avatar
Figured thats what it looked like, just making sure.
I have small indentions and low spots here and there... 1/16 of an inch or less, will need some kind of filler.... Or some thick build primer....
Old 03-06-2008, 11:55 PM   #17
jaros44sr
jaros44sr's Avatar
Thanks, North Wales my hometown, I'll check them out. Gotta love the weekly deductions
SAFETY FIRST
AS usual, off topic
Jim
Old 03-07-2008, 12:11 AM   #18
cstm68
cstm68's Avatar
yes that is what i use. in your case i would use some light filler like evercoat and then high build primer
Old 03-07-2008, 12:30 AM   #19
lyrikz
PITbut
lyrikz's Avatar
I was thinking of getting that stuff that had the metal in it... Guess its a bit harder to sand, but holds up better then anything else. I cant remember the name right now.
Old 03-07-2008, 07:12 AM   #20
bob1967
bob1967's Avatar
I used to use butcher discs until a friend showed me flapper discs now thats all I use, much easier to work with
bob1967 is offline   Reply With Quote
Old 03-07-2008, 09:06 AM   #21
67L30WGN
67L30WGN's Avatar
90 degree die grinder with 2" green 50 grit 3M Roloc sanding disks. I have full control and can get at and create almost any contour. All three of these areas had new metal sectioned in by welding and were shaped and cleaned up with the above combination, then finished with a 3" medium scotchbrite type roloc on the die grinder.
1972 Cheyenne Super 10 LWB
1965 Nova SS Evening Orchid
1967 Nova Wagon Factory Disc (1 of 565), 327/PG
1964 Ford Fairlane 500 HT
1962 Nash Metropolitan Convertible (Wife's car)
67L30WGN is offline   Reply With Quote
Old 03-07-2008, 09:34 AM   #22
lyrikz
PITbut
lyrikz's Avatar
You have a picture of your setup???
Old 03-07-2008, 10:01 AM   #23
67L30WGN
67L30WGN's Avatar
I'll take a picture of my setup for you tomorrow.
Old 03-08-2008, 07:57 AM   #24
67L30WGN
67L30WGN's Avatar
Here ya go... My two favorite tools for metal fab. I save the discs as they wear for smaller areas, until they are wasted.
Old 03-08-2008, 09:53 PM   #25
lyrikz
PITbut
lyrikz's Avatar
I have your top setup there.. I like that.. Only problem is i start getting water coming out of my tool after a bit... I have a water catcher on my compressor, but i dont think its installed in the right place... :shrug:
