03-06-2008, 09:43 AM | #1 |
anyone used this type flip kit?
03-06-2008, 10:07 AM | #2 |
Re: anyone used this type flip kit?
Before the airride I had the same axle saddles under my GMC. They did the job. If you can weld or can get it welded a cheaper solution is to get new axle saddles and put them on the bottom of the axle.
On the ones in the Ebay ad, when you put the U-bolt plate under the springs you have to drill a hole in it so the centering bolt can go through. If I can find mine I will post a pic of it.
88 Chevy C1500, step side, LS swap. 98 Crew Cab Dually, tow rig. 03 Dodge Neon. ECTA Ohio Mile record holder. |
03-06-2008, 10:07 AM | #3 |
You always get what you pay for, and this is a prime example. Ebay is cool for finding some things however, suspension parts will always be somethings I buy locally or at least something with a brand name.
You should buy new drop shocks and a c notch kit if you decide to order these or go with another flip kit.
Ken Morgan For fun: 1964 Volvo 122 For slow: 1984 Chevrolet C-10 For everything else: 1997 BMW M3 |
03-06-2008, 10:16 AM | #4 |
those have the offset holes in them if thats what you meant
03-06-2008, 09:21 PM | #5 | |
- Greg |
03-06-2008, 09:46 PM | #6 |
Right in front of you.
Starting bid....$39.99 + $22.99 for shipping.....all for $10 worth of metal....
Welding on new spring pads and using blocks w/new U-bolts is a better way to go.....and the spring plates shouldn't need drilled either....just clamp the spring pack and install the centerpin the other direction....
Pinstriping by Josh '78 Chevy Silverado SWB (lowered, 454) '90 Chevy Sport Truck '68 Dodge Charger R/T 1930 Ford Model A |
03-06-2008, 10:15 PM | #7 |
Chris
yea if you guys look art that price and read their feedback some exact same kits sold from them for $47.99 and $11.99 shipping. Then those are like $39.99 and $22.99 for shipping? I wrote them and asked why the crap shipping was that much for 2 small pieces of metal that can't way more then 2 lbs. It only cost me $10 to get a spring hanger shipped!!!!!!
All in all I considered using them for a cheap flip kit. As shown above the djm kit required a hole to be drilled too.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
03-07-2008, 12:35 AM | #8 |
Yep. I'm glad you posted yours. I had to use the nieghbors torch to do mine, when I dropped the truck the first go around my shop did not have electricity.
