Old 03-06-2008, 07:52 PM   #1
67c-10Texas
Anyone See Problems? Rear Mnt Battery
other than a pain to change and massive amounts of burnt rubber hanging off. does anyone see any problems with mounting the battery in this location?
has anyone tried it?
any suggestions? comments? concerns?
thanks
67c-10Texas is offline   Reply With Quote
Old 03-06-2008, 08:10 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Anyone See Problems? Rear Mnt Battery
From my experiences with my '39 Ford (battery in trunk) I wouldn't recommend it. If you do, use welding cable for your battery cables and use the solder on cable ends not the clamp on ones. I would also recommend running a ground cable to the motor from the battery instead of just using the frame as a main ground source. Also be sure and use ground straps from the motor to the frame and body. I melted two sets of clamp on battery cable ends before I figured all of this out.....
LockDoc
Leon
Old 03-06-2008, 08:17 PM   #3
jaros44sr
jaros44sr's Avatar
Where did you get the battery box, or did you build it?
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 03-06-2008, 08:30 PM   #4
67c-10Texas
LockDoc - understand on the cable issues. i have ran rear mount batteries before and know the charging and grounding issues. i will also have charging lugs behind the rear flip down plate.
(Where did you get the battery box, or did you build it?)
Smileys racing. they cater to the dirt track guys but you would be suprised what you can make work with some creativity...
http://www.smileysracing.com/
more focused on fitment.... i might need some measurements...
Old 03-06-2008, 08:41 PM   #5
pro street 70
pro street 70's Avatar
that look like my truck same tray @ same spot on frame.like lockdoc said use good cable @ solder ends on lots of good grounds i used frame for main ground but welded studs on frame for grounds . make sure you use battery kill switch at back of truck because you get a short you could burn up the truck.also need it if you drag race the truck.bought my tray at capital speed shop on line its a nice tray and its heavy duty
1970 chevy short step blown 355
pro street 70 is offline   Reply With Quote
Old 03-06-2008, 11:57 PM   #6
67c-10Texas
Did you weld it on or bolt it on?
Old 03-07-2008, 12:25 AM   #7
Andy4639
Old member
Andy4639's Avatar
Will it have enough room to be taken out with the bed on? If you aren't racing the truck why do you need it in the rear? Seems to be a lot of added work for no gain's. Cool factor isn't that great and you can have some pretty neat cover's made for the stock battery. Just my cent's worth.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-07-2008, 12:36 AM   #8
67c-10Texas
racing - more weight over the axle
there is just enough room to shimmy it in
Old 03-07-2008, 01:21 AM   #9
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
I put two in the back, used welder wire about the size of your thumb.Never had to use it as a DD but never ran into problems.
sneakysnake is offline   Reply With Quote
Old 03-07-2008, 02:30 AM   #10
pro street 70
welded it on i think bolts may dig into battery.used a optima battery red top put battery switch under roll pan near plate
Old 03-07-2008, 03:58 AM   #11
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Kill switch is nice, but to be safe you need a fuse! if welding cable gets nicked/cut and shorts out - it's history! always size the fuse for the size of wire close as possible to the battery.
Other than that it looks good to me. I also recommended a maintenance free battery like Optma.
I had a battery in the rear on my last car, it was great.
Vaya con Dios
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 03-07-2008, 04:07 AM   #12
Deuce
Deuce's Avatar
I did the same thing but on the passenger side to help balance my girlish weight.
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
