Old 03-07-2008, 12:24 AM   #1
prg machine
prg machine's Avatar
speedo cable
I just got a new cable for a K-20 from Brothers and there ain't no way it will reach the way the old one did. The original went up the firewall and tru to the inst. cluster. They insist it is the right one. I ambringing it up under the trans hump and then to the gage cluster. Thisworks. Anyone else know anything about this subject? any experiences?
69 K-20 cloned to a 67 with front clip and some other stuff.
383 .040 over
Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears:
prg machine is offline   Reply With Quote
Old 03-07-2008, 12:27 AM   #2
Andy4639
Old member
Andy4639's Avatar
Re: speedo cable
Take the one you just got and go to any parts store to match it up. I just bought a new one and it's about 12" longer than my stock 2 wheel drive was.
I bought mine at Auto Zone with the housing too!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-07-2008, 02:19 AM   #3
prg machine
Re: speedo cable
I spent my money with Brothers.......................live and learn. the 12 inch difference is what it needs!
383 .040 over
Old 03-07-2008, 03:12 AM   #4
jef5150
Inline 69
jef5150's Avatar
Re: speedo cable
did you get the Item:# PLCBL01 ? its 68" long -will not work on 4x4
jef5150 is offline   Reply With Quote
Old 03-07-2008, 06:42 AM   #5
wibilly
wibilly's Avatar
Re: speedo cable
i bought a universal replacement inner at o'reilys dirt cheap and works great
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 03-07-2008, 07:39 AM   #6
prg machine
Re: speedo cable
I have no idea what they sent. They insist that it is the right one for 4x4
383 .040 over
Old 03-09-2008, 02:34 AM   #7
AH619
AH619's Avatar
Re: speedo cable
Oreillys, Under 20 Bucks With Housing And They Have All Lengths In Stock
72 2wd lwb cheyenne super youngest son.green/white
72 2wd lwb cheyenne super oldest son.green/white
71 4wd 3/4 cheyenne super frame off manderin
copper / white 4 inch lift. FINALLY DONE / SOLD
72 4WD SWB CHEYENNE BLUE/WHITE 388 AUTO
REMEMBER THE COPS NEVER THINK ITS AS FUNNY AS YOU DO. NORWOOD SURVIVOR
COPPERTONE BUILD THREAD/ http://www.67-72chevytrucks.com/vboa...d.php?t=259856
AH619 is offline   Reply With Quote
