Old 03-07-2008, 04:32 AM   #1
tcb-1
Nothing to see here.....
tcb-1's Avatar
No load battery voltage....
my truck is still giving me starting issues. fuel system is fine now.
still running a points distributor so, what should my battery be registering, at no load, cold. I'm getting 12.2 but I'm thinking that not enough.
I know, I need someone to crank while I put a meter on the battery...... the battery gauge in the truck shows right in the middle during cranking, but that doesn't mean a lot.
Anyone have an idea what voltage a points set up needs to function. On my old Triumph bikes, that I went to electronic ignition, I had to have at least 14 volts registering on the battery, cold or it would not start.....
thanks, sorry for a stupid question
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 03-07-2008, 04:36 AM   #2
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: No load battery voltage....
your battery is weak. Should be higher.....I'll find a link for you.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 03-07-2008, 04:40 AM   #3
Sport/Truck
Sierra Grande Club
Here it is. http://www.odysseybatteries.com/charging.htm
BTW these battery's rock!
s/t
Old 03-07-2008, 05:34 AM   #4
DavesRide
DavesRide's Avatar
Do you have a generator with external regulator?
I have watched many charging systems (alternator) if not under load go towards 13+ Volts with internal alternator. What again are your starting problems? The gauge inside truck can be very deceiving. My brother's old 66 gauge (generator) would peg if you honked the horn while running and then go back normal. Check at the battery with a good meter like a FLUKE and check it without any load and check with load like all lights on, fan on, and radio. It should never drop below 12 V ever or it is discharging battery.
R.I.P ESLL Even as the body dies the spirit lives on in the people you touched
DavesRide is offline   Reply With Quote
Old 03-07-2008, 06:11 AM   #5
joedoozer
is Certifiable
joedoozer's Avatar
yeah test it with a good known meter. and go to napa or your local parts store and buy a toaster. battery load tester, that will tell you what shape it is in.
joedoozer is offline   Reply With Quote
Old 03-07-2008, 06:51 AM   #6
tcb-1
tcb-1's Avatar
since I've been into restoring bikes so long, my charger is only for a small 12 volt battery. soooooo I have the battery in the garage on the motorcycle charger. I'm going to leave it on all night. I thought the battery (Exide) was still "good", but it may be getting the boot soon.....
I actually have a digital Craftsman volt meter, but I may run to Napa and buy the battery load tester as well (thanks Joedoozer!)
Doug
Old 03-07-2008, 08:03 AM   #7
HotGMC
i dont know to much on the subject, but i know mine runs around 15 3/4-17 volts.
is it having issues starting or just you think the volts are low?
HotGMC is offline   Reply With Quote
Old 03-07-2008, 08:09 AM   #8
tcb-1
tcb-1's Avatar
both. but I think the battery is the culprit.
Doug
Old 03-07-2008, 08:28 AM   #9
DavesRide
DavesRide's Avatar
Having tested many autos for voltage I have never seen any that high. That will boil the juice out of a battery.
Old 03-07-2008, 08:38 AM   #10
AlienYouth
AlienYouth's Avatar
like 12.7-13 is full charge
somethin like 14-15 while running
Picturesss
71 C10 383/TH400
13.65 @ 99... 2.06 60' spinnin :/
AlienYouth is offline   Reply With Quote
Old 03-07-2008, 08:51 AM   #11
DavesRide
DavesRide's Avatar
Never seen that on a normal vehicle. I really haven't. 9v under full load is lowest on good batttery under full load and 14.v while regulator is in "give it all to me" mode.
Old 03-07-2008, 09:16 AM   #12
Wreckless_71
Wreckless_71's Avatar
your battery should be right around 12v if you walk out of your house and put a volt meter on it... it should be about 14.6v while charging (running). Dave's right 15-17 will create a very unsatesfactory smell from your battery and is quite dangerous, I deffinitly would not be standing around to test that battery!
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project.
1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver.
Wreckless_71 is offline   Reply With Quote
Old 03-07-2008, 09:45 AM   #13
jef5150
Inline 69
jef5150's Avatar
just because the voltage is 13-14volts at the battery while the motor is running doesnt mean your battery has enough "AMPERAGE" to re-start the car.It means your alternator is charging.
i would swap batteries from a good car,if it cranks over good and starts right up replace your battery.If you still have the same symptoms i would then check for loose cable/oily connection, especially the ground.Even if your "battery charger" says its "fullycharged" you could have a bad cell and it will still "slow crank" your motor .
jeff
jef5150 is offline   Reply With Quote
